Transposing and rotating G Code
DRobs86
Re: Transposing and rotating G Code
Post by DRobs86 » Tue May 17, 2016 5:39 pm
Yes I did. I do have a feeling now that I might have an old 32bit java version still on my system that is trying to run. I will dl 32 bit goko to see if that helps.
Thanks again.
DRobs86
Post by DRobs86 » Thu May 26, 2016 3:54 am
I am up.
It was a path variable issue. I had to add a java directory in my environment variables and add a reference to Java in the Path variable. I don't know why other Java apps ran if there was a problem.
This link showed me exactly what to change:
http://www.mkyong.com/java/how-to-set-j ... indows-10/
Also, this seems odd, but I downloaded Goko 32bit and my path variable is pointing to an x86 program files copy of Java. I am no expert, but I don't see why that works. I am just glad it does.
Now on to checking out Goko.
Thanks for the software and the support!
PsyKo
Post by PsyKo » Thu May 26, 2016 6:07 am
Glad to ear that :)
Shapeoko #736
