S03 Fire
KAScnc
S03 Fire
Post by KAScnc » Wed Sep 28, 2016 3:57 pm
This popped up on my youtube feed, has this been posted here? Crazy!
(ignore the intro...)
northbear
Re: S03 Fire
Post by northbear » Wed Sep 28, 2016 4:08 pm
This should be shown to anyone who has ever considered running their cnc unattended.
My buildlog is here
madhatter
Re: S03 Fire
Post by madhatter » Wed Sep 28, 2016 4:21 pm
Oh man, my worst fear come to life. . .
I have run unattended before, but NEVER with code that has not run without issues. I'll usually run new code a couple of times before I am comfortable enough to walk away from it for 10-15 minutes at a time.
SO3 #0054
DWP611 - SuperPID
Prusa i3 MkII
SolidWorks 2015
Re: S03 Fire
Post by WillAdams » Wed Sep 28, 2016 5:08 pm
http://www.shapeoko.com/wiki/index.php/ ... _Checklist
Consider the possibility of the spindle starting a fire by friction and take suitable precautions (having a fire extinguisher handy, &c.).
Monitor the machine while it operates, ensuring there is no build-up of dust, debris or fumes, and that nothing works loose...
Note: Be careful to recycle or safely dispose of milling debris and dust, keeping in mind flammability, (potential) spontaneous combustion, and chemical considerations.
hatallica
Re: S03 Fire
Post by hatallica » Wed Sep 28, 2016 5:45 pm
KAScnc wrote: (ignore the intro...)
Ignore the intro? No way! Local news interviews are the best entertainment.
Great safety reminder, though.
Shapeoko3 #1153
Brian Stone
Re: S03 Fire
Post by Brian Stone » Wed Sep 28, 2016 8:45 pm
Talk about learning the hard way. Yikes.
Shapeoko 2 #7353
CastIrony
Re: S03 Fire
Post by CastIrony » Wed Sep 28, 2016 8:51 pm
It's actually kind of nice to see just how much time there was between when things first went wrong, to when the smoke started, to when the actual fire started. If the operator had been present they could have easily cut the power the second the clamp failed and only been out a piece of wood.
KAScnc
Re: S03 Fire
Post by KAScnc » Wed Sep 28, 2016 9:21 pm
not sure what I was impressed with more, router or that bit...
With the smoke shooting straight up, wonder if some type of vent was running.
Gadgetman!
Re: S03 Fire
Post by Gadgetman! » Sun Oct 02, 2016 12:56 pm
Exactly HOW was that piece clamped?
(Bubblegum and paperclips doesn't count... )
Also, the operator allowed dust to build up everywhere on the piece. And with the RPM/Feed he's been running, that's a mighty fine dust. I guess they should consider themselves lucky that it didn't go boom...
zamp
Re: S03 Fire
Post by zamp » Sun Oct 02, 2016 4:13 pm
Since watching that video I've done some google searches that will make me hesitate before using a downcut bit to penetrate all the way through metallic work pieces. It turns out a lot of people have written about the danger and some others have also experienced fire as a result of similar operations. Googling for "downcut bit drill through fire" turns up some of these.
