Reasonable expectation of flatness
aarvidsson
Post by aarvidsson » Wed Jan 18, 2017 9:00 pm
I'm just about to tram the spoilboard of my newly rebuilt Shapeoko, and it occurred to me: how flat can I reasonably expect this board to stay? It's an 16mm MDF that i'll remove 0,3mm from - how flat will it stay with changes in temperature, humidity and such?
For you guys that want a very high consistency in the Z axis (0.1mm and such) - how do you do it? Metal bed? Tram whatever piece of sacrificial material before running every job?
ShapeOko 2 #4143
CastIrony
Re: Reasonable expectation of flatness
Post by CastIrony » Wed Jan 18, 2017 9:42 pm
Yeah, I've noticed some significant swelling from the piece of thick MDF I use as a spoilboard/mounting board. In the short term I'm probably going tram it, but eventually I would like to replace it with a material that won't warp or swell with changes in humidity, like HDPE.
Post by WillAdams » Wed Jan 18, 2017 11:33 pm
If you spray it w/ spar urethane or some other sealant before (top, bottom, sides and into all the holes) and after tramming (touch up where you cut), it should stay reasonably flat.
DanMc
Post by DanMc » Thu Jan 19, 2017 4:31 am
I use mdf. If I'm working on something critical I'll tram a second sacrificial board specific to that job, but then I usually mill a jig specific to each project or series anyway with holddowns where I need them. Even with something that won't swell is the table the machine is resting on stable to <0.1mm? There's too many variables and it takes no time to skim the surface before a project.
aarvidsson
Post by aarvidsson » Thu Jan 19, 2017 7:26 am
Good points from all of you, thank you very much!
ShapeOko 2 #4143
Post by WillAdams » Thu Jan 19, 2017 2:27 pm
For an example of such jigs, see the calipers which I made: http://www.shapeoko.com/projects/project.php?id=154 --- they also made use of sacrificial aluminum and nylon screws.
