Lost Coordinates and how to recover from them
The_Researcher
Post by The_Researcher » Thu Jul 20, 2017 5:04 am
Greetings all, I am seeking help on the following.
I have a 2 tool path cut. The first tool (60D) is successful, while i am changing the tool i move the router due to the cullet nut being to tight. I tell the carbide to go back to home, and now i see that its off by some measurement. how do i go back to the original coordinates so i can continue my second tool?
Wayne
Re: Lost Coordinates and how to recover from them
Post by WillAdams » Thu Jul 20, 2017 5:36 am
Ideally you would write down the offset from the machine origin.
Are there features you can measure to determine the stock origin?
The_Researcher
Post by The_Researcher » Thu Jul 20, 2017 1:37 pm
I have been semi successful manually getting my alignment back but its never perfect. I will write down the coordinates as a work process from now on.. Thanks..
Wayne
Dan_the_Chemist
Post by Dan_the_Chemist » Thu Jul 20, 2017 6:21 pm
Generally I have found that if I re-home the machine after each tool change the X and Y stay pretty good. The biggest challenge I've had is with the Z.
I have several places marked on my machine where I can put a 123 block to use as the height standard to set the Z for bits. By placing the block consistently and using the same portion of the block every time, I get pretty good adjustment on the Z.
If the raw material covers all of the accessible work area and I won't have an unchanging surface to place the 123 block for Z setting, then I try to cheat and pre-drilll a small blind hole in the stock which will accept a dowel pin that can be removed and replaced when needed (make sure to clean out the hole). Cleverly placed holes can look like a design element rather than a production fixture.
If none of that works I use a small steel plate, a magnetic indicator holder, and a Last Word type indicator coming in from a marked place off the work (or even off the waste board) to set the Z height.
fasteddy
Post by fasteddy » Fri Jul 21, 2017 1:06 am
I ran into the same issue over the winter. I was 3 hours into 3d carve when I screwed something up (don't remember exactly, but I paused the program and somehow ended losing my home.) However, after 5 minutes of utter despair, I rehomed the machine and realized that linuxcnc keeps your offsets. I had to start the program over, but I managed to save the project.
