Zeroing bit but cutting air?
Fly Capt
Post by Fly Capt » Sat Dec 30, 2017 10:28 pm
I have had pretty good success with the Fusion GCode the past week tweaking and learning.
But today I wanted to cut out a name sign from 1/4" Masonite. Could figure it out in F360 so tried running Carbide Create to create a sign. Was a simple name with CC dong the design and post went well. The simulation looked perfect.
The problem came when running the code.
After jogged the XYZ to the starting point, mid left as designed and top of surface. It ran X&Y perfectly but the first two passes Z was cutting air and on third pass bearly scratched the top surface.
What am I doing wrong?
How can the simulation turn out so well but not work
Re: Zeroing bit but cutting air?
Post by WillAdams » Sun Dec 31, 2017 1:11 am
I suspect you have an electro-mechanical problem.
Please check:
- http://docs.carbide3d.com/shapeoko-faq/ ... et-screws/
- belt tension: https://www.shapeoko.com/wiki/index.php ... ko_3#Belts (careful not to bend the motor shaft)
- possibly too strong Z-axis springs --- try removing one --- if that works, let us know at support@carbide3d.com
Fly Capt
Post by Fly Capt » Tue Jan 02, 2018 11:04 am
Neither of those options. But did locate the Operator Error and fixed it. Inavertaely set Max Depth of Cut to less than the board thickness so regardless of Z zero it would only cut so deep which makes perfect sense now. But did get me to level off the table to less than .005 of flatness.
