touch plate vs tool length probe
Posted: Tue Feb 20, 2018 9:46 pm
by jkanzaki
Hey Everyone,
Would anyone mind explaining to me the difference between a tool length probe like this one (The Nomad seems to come with one and have a little spring in it). This is a similar product I found online.
http://www.ebay.ie/itm/Werkzeuglangense ... 2459225796
Vs
https://www.ebay.co.uk/itm/Cnc-Z-Axis-R ... 1c9fe92539
Has anyone used one of these tool length probe similar to the one in the first link? Their build quality seems to be superb, after all, they are MADE IN GERMANY right? haha.
What would be the benefit of using the tool length probe vs a zero touch plate? Aside from the build quality.
Re: touch plate vs tool length probe
Posted: Wed Feb 21, 2018 2:48 pm
by RobCee
The difference will be in repeatability and build quality.
Both will function the same way, although I doubt that the cheaper one has a nice spring in it. The spring is important to save the tip of your sharp tools; although many people have success with their un-sprung versions. I find I run my tool into mine far too often, so I like the little extra time I get with my spring to hit the E-Stop!
The other nice feature of a sprung tool length probe is that the probing can be setup to confirm on the lift-off, rather than the touch (if that makes sense). This leads to a more accurate and consistent reading from the probe. The way I use mine is to probe down onto it at a fairly high speed, once it touches I probe up until the contact is lost at a much slower speed. This gives me a very repeatable process.
Having said that, the price differential is fairly extreme.
Posted: Thu Feb 22, 2018 3:48 am
by jkanzaki
Did you build the probe your self? Yes the price is quite extreme.
RobCee wrote:The difference will be in repeatability and build quality.
Posted: Thu Feb 22, 2018 8:15 am
by RobCee
Yes, I did build my own probe. It's fairly simple if you have access to a lathe.
Posted: Mon Jan 14, 2019 1:28 pm
by aggiedan97
RobCee wrote:Yes, I did build my own probe. It's fairly simple if you have access to a lathe.
Would you mind sharing your design for your diy probe?
