And so the spend commences
My SO3 has arrived!!
I have to make a wasteboard for mine as my friend remove it from the package to make it easier to transport. As he saved me over $400 us in freight and 15% Duty I guess I can't complain. I have the MDF cut and just have to Mark and drill holes.
Now I need to sort out some cutters.
I had a look at Drillman1 on eBay and realised I have a lot to learn about cutters. So I have decided to go with some from carbide 3D
I base my selection on the wiki and will get 3 of 201, 2 number 202 and 2 number301. I have decided to just stick with quarter inch cutters until I feel confident enough and need 1/8" cutters.
Raining here today so I intend to spend the time working through some vcut tutorials and also Carbide Create
Re: And so the spend commences
It's not as bad with a CNC router as with a mill (on a mill tooling and workholding can easily be half the cost of the machine, so up to a third or so of the total investment).
Buying inexpensive ones to start isn't bad so long as breakage isn't frustrating, and don't overlook suitable router bits from your local building supply stores.
There's some basic information at: http://docs.carbide3d.com/support/#tooling-support
Thanks Will,
It's the same with wood turning lathes..the cost is in the tools as much as the lathes.
I wondered about using router cutters especially as I have several I use with my big Hitachi and Triton routers.
That chart is also useful.
At the moment I am struggling with marking up the hole centres on my wasteboard..pretty hard to eyeball to decimal places of a mm to meet the figures on the template. I might have to get it done on a CNC machine
As a thought, it's totally possible to create your own wasteboard from plate aluminium. When I bought mine a while back, one of the first things I did was to replace the wasteboard with 4mm aluminium. It works well.GerryAttrick wrote:I have to make a wasteboard for mine as my friend remove it from the package to make it easier to transport.
Possibly interestingly, I bought two aluminium plates to be made into wasteboard. 4mm and 6mm.
I figured the 4mm would be for practice (eg first attempt), as I was liable to screw something up. With the plan to "make the real one" using the 6mm.
However... the first attempt, using the 4mm plate has worked out so well that I never bothered to swap over to the 6mm waste board. That's just been sitting around (with no holes drilled) since then. I must get around to doing something with it some day.
Last edited by AnonymousPerson on Thu May 17, 2018 5:39 pm, edited 1 time in total.
My problem is that I have 2 plans with measurements for the wasteboard - both drawn by Edward. One is solely in mm and the other in mm/imperial. The metric measurements are different on each one! Not by much but when I have to put a bolt into a threaded hole "not much" is too much.
I thought of using the holes in the frame to mark the wasteboard but I'll need to work out how tight the wasteboard fits into the frame. If its too tight/loose will it cause a problem aligning the gantry or anything else at assembly?
Hmm..best I start a new thread on this one after I have had a chance this weekend to lay the parts out and look at things in more detail
Lucky I have plenty of MDF on hand...I think I am going to need it before I have everything running.
Please let us know which files you are using and from where and we'll try to reconcile this (or at least get some notes on the wiki about it).
@ willadams. The incorrect(???) Drawing is dated 23/4/2015 (ref S3099)and I think I may have picked it up from a post on this site but I have no idea where. I do know it appears to be referenced in an earlier post re wasteboard dimensions by RawIndesign where the dimensions were "changed" by 1.73mm _ incidentally that incorrect sized waste board is still available for download along with a workaround!
The dimensions I am currently working to are those from the wiki with a width of 717.55mm. In the earlier drawing the measurement is shown as 721.73mm and there was discussion around the missing 1.73mm in the Rawindesign drawing. The consensus seemed to be that 721.73 was correct and yet the latest drawing by Edward on the wiki has a width of 717.55mm!
How critical is that figure given I have no equipment capable of measuring to 0.55mm. Would using an overall width of 718mm work so long as holes are inset 40mm?
@WillAdams
Finally tracked how I managed to get two different copies of the drawings for the wasteboard.
If you go to the SO3 Wiki under Drawings:
Wasteboard: http://carbide3d.com/files/S3_Wasteboard.pdf S3099[121][122] Unofficial_S3099_xl.svg
And click on the pdf you get the latest(??) drawing (S3SBB)with just metric measurements. However if you click on the S3099 link (and maybe the Unofficial 3099xl.svg) you get an earlier drawing with both metric and Imperial measurements and the sizes DIFFER!
The S3099 has Metric measurement of 721.73mm- this was subject to some discussion around a set of drawings provided by RawIndesign where he has a measurement of 720mm and there seemed to be some consensus that this was wrong and there was a missing 1.73mm
Drawing S3SBB by Edward and the later of the two has measurements for the Wasteboard with a figure of 717.55mm. I have no idea how the first drawing by Edward had 721.73mm was reduced to 717.55mm unless the frame was altered or the hole centres re-aligned.
As I need to make my own Wasteboard I really need to get the correct dimesions…a file that I can give to a local Cutshop so they can produce it on a CNC would be great
Maybe this now needs to be moved to a separate topic - seeing as I seem to have hijacked my own original post
I've edited the wiki page to make that obvious.
