software choices
jpmreno
software choices
Post by jpmreno » Mon Jun 04, 2018 4:10 pm
i bought Vcarve Pro thinking I had to have it for my Shapeoko XXL. Now I'm finding out I need other software too. How many different software do I need?
Re: software choices
Post by WillAdams » Tue Jun 05, 2018 1:29 pm
You only need Vectric VCarve Pro if there's some specific feature which it has which you're willing to pay for.
The only software you should need is:
- Carbide Create --- this will allow you to draw and modify designs and assign toolpaths, see: http://carbide3d.com/carbidecreate and http://docs.carbide3d.com/assembly/carb ... tutorials/
- Carbide Motion --- this will allow you to control the machine, jogging it, setting zero relative to the stock, and sending files to it: http://carbide3d.com/carbidemotion/ and http://docs.carbide3d.com/assembly/carb ... userguide/
(there's a bit more on the wiki which may be of interest)
You can see how this software fits together in the tutorials: http://docs.carbide3d.com/tutorials/#shapeoko-tutorials
The usual additions are:
- a vector editor / Bézier curve drawing program --- this is used as a front-end for creating designs more easily and with greater facility than Carbide Create readily affords. The usual choice is Inkscape: https://www.shapeoko.com/wiki/index.php/Inkscape
- a CAM program such as Vectric which offers more features than Carbide Create
- a 3D CAD and CAM pair for folks doing full 3D
There's a bit more at: https://www.shapeoko.com/wiki/index.php/Software and related pages on the wiki.
If you'd let us know what sort of work you wish to do we could be more help.
stuarttaylor00
Post by stuarttaylor00 » Mon Jul 02, 2018 11:53 am
Vcarve pro (for design, and creating Gcode) and Carbide motion ( to control your machine and send Gcode to it - it is free) are the only two programs you need to make almost anything you could want on your shapeoko.
Carbide Create(for design and creating Gcode - also free) is a great simple software to design your projects, to make anything complex it needs the support of a vector editor, as Will mentioned. It is getting updated all the time and is very easy to use.
Personally I use Vectric Aspire (next level up from Vcarve Pro) and Carbide motion, it's a pretty great combo
Shapeoko 3 #1095 - Aluminium wasteboard, homing switches, Modified Z plate, Makita 700 router
Flashforge Dreamer Dual extruder 3D printer
2013 Ducati 848 Evo ;)
chilinski
Post by chilinski » Tue Jul 03, 2018 2:53 am
Fusion 360 (free for hobbyists) and grbl-panel (free) to control the S03 and send gcode are all I have needed in about a year. Fusion 360 because I can do a lot with it including 3D printer projects. Grbl-panel because it has a limited number assignable macros and programmable table locations. But most of my work is pretty flat, uninteresting and repetitious.
