touch probe
Jeff
touch probe
Post by Jeff » Fri Mar 29, 2019 12:41 pm
I am building kitchen cabinets. I want to use a 3/8" plunge router bit.
In my design the vectors for the dado extend pas the out side of the wood.
So with that said If i do a x & y probe with the .25end mil, then can I change to the 3/8"dia bit and do the top Z touch off to the top of the material
Will that work.
Jeff
Picengraver
Re: touch probe
Post by Picengraver » Sat Mar 30, 2019 12:07 pm
Should work if your gcode file calls for the 3/8 bit. The X/Y zero point should remain the same unless you move the spindle when changing bits. Why can't you set X/Y with your 3/8 bit?
Re: touch probe
Post by WillAdams » Sat Mar 30, 2019 1:20 pm
Yes, that will work.
X and Y probing has to be done with a matching/supported endmill to get the center position, but once it's established, it's invariant for any endmill which is installed.
Jeff
Re: touch probe
Post by Jeff » Sat Mar 30, 2019 1:28 pm
So then I can do what I said in the last line.
And once the x and y are set I can move the gantry up and away to do a tool change and a Z probe to the top only with a 3/8" 2 flute bit, load the file and run from there Right ?
Jeff
Re: touch probe
Post by WillAdams » Sun Mar 31, 2019 12:18 am
Yes, that should work.
Jeff
Re: touch probe
Post by Jeff » Sun Mar 31, 2019 10:57 am
So could you explain why it makes a difference which size bit you are going to use. To do the xyz phobe.
Jeff
Re: touch probe
Post by WillAdams » Sun Mar 31, 2019 8:16 pm
The probing is done from the edge of the endmill --- the system needs to calculate the distance from that edge to the center, which requires that the diameter be known.
Jeff
Re: touch probe
Post by Jeff » Mon Apr 01, 2019 10:11 am
thanks I got it
Jeff
