Rotozip or Laminate Trim Router for the spindle?
northbear
Post by northbear » Thu Apr 12, 2012 10:13 pm
Has anyone built a Shapeoko (or is planning on building one) using a Rotozip or Laminate Trim Router for the spindle?
I have a rotozip and a trim router already was thinking I could use them for a CNC machine and was wondering if the Shapeoko would be a good fit. My concern would be with the weight (over 3 lbs) as it is heavier then a dermel.
Below are links to the rotozip and trim router I would be looking at using. The rotozip is variable speed (15,000 - 30,000 rpm )and the trim router is fixed speed (30,000rpm)
http://www.amazon.com/Porter-Cable-7310 ... B0000222Z6
http://www.amazon.com/RotoZip-RZ10-2100 ... 792&sr=8-2
My buildlog is here
Post by edwardrford » Fri Apr 13, 2012 1:21 pm
I just picked up the Dewalt D660 last week from amazon for about $55. It comes with both 1/8" and 1/4" collets.
My initial thought is *yes!* its going to work. I need to cut my new mounts so I can actuallt try it out though.
Right now I'm focusing on the dual drive system (bearing was delivered yesterday!), once that's done I'll put the machine back together and cut the new mounts.
Sent from my BlackBerry 9930 using Tapatalk
northbear
Re: Rotozip or Laminate Trim Router for the spindle?
Post by northbear » Sat Apr 14, 2012 2:30 am
The Dewalt dw660 looks very similar to the rotozip as far as weight and power is concerned. Look forward to hearing if it works!
My buildlog is here
minorthreat
Post by minorthreat » Tue Apr 24, 2012 4:47 pm
I'm planning a build using the Ryobi ONE+ Cordless Speed Saw Rotary Cutter.
Power-wise it's equivalent to the rotozip. it's under 30$ in store @ Home Depot (packaged w/o batt), has a beefy bearing right behind the chuck, accepts 1/4" and 1/8" bits, and it's DC, so power supply/speed control integrate very nicely.
I'll let you know how it goes.
northbear
Post by northbear » Tue Apr 24, 2012 9:49 pm
minorthreat,
I look forward to hearing how it works for you!
My buildlog is here
calica
Post by calica » Wed Apr 25, 2012 12:20 am
minorthreat,
What you you going to use for a powersupply? How much current does it use?
lasershark1
Post by lasershark1 » Wed Apr 25, 2012 2:01 pm
minorthreat wrote:I'm planning a build using the Ryobi ONE+ Cordless Speed Saw Rotary Cutter.
Hrm... I forgot about that. I have one at home I bought for woodworking a while back. Without the battery it's pretty light. Wire in power and you're all set. I was on here trying to find the model # of the B&D "dremel" that was posted and came across this.
The more I think about it the more I think that would be an awesome tool for it. It's got a high rpm, very solid and the 1/4 bits are a huge plus. Add to it the fact it's DC makes it that much nicer.
No idea on its power draw, it runs off 18v batteries normally. Maybe I'll test it out tonight before buying a power supply.
minorthreat
Post by minorthreat » Wed Apr 25, 2012 8:40 pm
calica wrote: What you you going to use for a powersupply? How much current does it use?
I'll probably start by running it off the 24v rail, I've got a few h-bridges lying around so I might throw one in for speed/dir control. I'll check the current draw on ryobi tonight and post what I find out.
Post by edwardrford » Wed Apr 25, 2012 8:48 pm
My guess is 5A.
'Price is Right' rules apply to anyone else who's guessing :-)
minorthreat
Post by minorthreat » Wed Apr 25, 2012 11:51 pm
edwardrford wrote:My guess is 5A.
5.6A @ 20V
She's a beastly beast.
