https://drive.google.com/file/d/0B01dPF ... sp=sharing
The left side features on the mounts will snugly fit a 1" PVC pipe which I will use as part of the dust collector system ... which will be another project for another day.
The material was 3/4 Birch plywood. If i recall correctly, the feed rate i used was 38in (965mm). The cutting depth was .06in (1.524mm). The speed was 30,000rpm.Audiophyle wrote:What material & feed rates were you using with your Makita? Machine looks good, & I like your integrated vac mount.
Nope, you can buy if from Grainger. it is a 3M product that looks like masking tape.awesomename wrote:They grey VHB stuff?
I have the aluminum, hardware, and am about halfway through designing it. Its just a matter of time management now. I have gotten really busy with travel, and spring time house work. I hope to get a video up next week about using a 1/8 bit in the makita with a collet sleeve, and then the video about the new mount the following week. Sorry for the delay, but sometimes life gets in the way of fun.jtopoko wrote:Any news on the updated mount ? Interested to see your alu solution.
