Amazon is now discounting Dewalt DPW611
tbfleming
Re: Amazon is now discounting Dewalt DPW611
Post by tbfleming » Thu Dec 18, 2014 1:28 am
chomdh wrote:This would be a sweet upgrade. What mods do I need to get the most out of a dnp611?
Do I need to bolt my x axis together or change to nema23 motors?
Right now the only upgrades I have are a dw660 and acme z.
I run a 611 on my Shapeoko 2 without any other upgrades. I get amazing feed rates with it.
chomdh
Post by chomdh » Thu Dec 18, 2014 3:10 am
Ok glad I ordered. $79 seems like a good deal. What mount do you use? I currently use mounts I milled from hdpe for my dw660 and they don't clamp as tight as I would like.
Shapeoko2 #3702:
Post by WillAdams » Thu Dec 18, 2014 3:40 am
As noted below, chomdh found a post which indicates it includes collet wrenches and collets.
I.C. has mentioned working on a mount for the DWP-611 previously, but it hasn't shown up on the shop or the wiki --- there are a couple of designs / links there though: http://www.shapeoko.com/wiki/index.php/Spindle_Options
Inventables does carry a mount which will fit the DWP-611 (and other routers w/ a ~69mm diameter such as the Bosch Colt): https://www.inventables.com/technologie ... ndle-mount
tbfleming
Post by tbfleming » Thu Dec 18, 2014 3:43 am
chomdh wrote:Ok glad I ordered. $79 seems like a good deal. What mount do you use? I currently use mounts I milled from hdpe for my dw660 and they don't clamp as tight as I would like.
I milled mine from hdpe. I used a design posted on this forum that was originally for aluminum mounts. It has a bump which fits into the 611's vertical channel; this prevents it from twisting.
chomdh
Post by chomdh » Thu Dec 18, 2014 3:50 am
Sweet I was hoping for an anti twist feature on the mounts.
According to this post the dnp611 does come with collet and wrench.
http://www.shapeoko.com/forum/viewtopic.php?f=8&t=2230
Shapeoko2 #3702:
Brian Stone
Post by Brian Stone » Thu Dec 18, 2014 4:35 am
WillAdams wrote:Inventables does carry a mount which will fit the DWP-611 (and other routers w/ a ~69mm diameter such as the Bosch Colt): https://www.inventables.com/technologie ... ndle-mount
That's the one I'm going to try.
Shapeoko 2 #7353
Woodworker
Post by Woodworker » Thu Dec 18, 2014 1:14 pm
I used the mounts from a different thread here that were in aluminum, mine are currently made of plywood. I've been running it since June on a mostly stock machine with good results. I do find that the machine has to be kept adjusted or there will be a lot of flex, especially during plunges. Keeping the feed rate conservative helps. I'm running it this way just to get through the Christmas season and then I will be building a larger version with a stiffer, and longer, X rail. Long term a spindle of this weight may result in loosening of nuts due to inertial forces racking and twisting the rails. The speed control is very good and the soft start makes it gentle on the machine.
chomdh
Post by chomdh » Mon Dec 22, 2014 11:36 pm
Woodworker - I'd like to start with plywood mounts like you have made. I know I saw a picture of yours before. Do you have the link to that post and will you post the svg file of your modified slot nut design?
I'm receiving the dnp611 as a gift but want to have the mounts ready to go:
Shapeoko2 #3702:
Woodworker
Post by Woodworker » Tue Dec 23, 2014 1:39 am
Here is the link with the original svg
http://www.shapeoko.com/forum/viewtopic.php?f=30&t=3435
I will see if I have my svg, I lost a drive earlier this year. I will post my original article that explained how I modified the original.
chomdh
Post by chomdh » Tue Dec 23, 2014 3:20 am
OK found the pic of the one you made woodworker:
http://www.shapeoko.com/forum/viewtopic ... 579#p31579
If you have the svg that would be great, otherwise I should be able to add the notch for the nut.
Shapeoko2 #3702:
