Mount for a Makita RT0701
Re: Mount for a Makita RT0701
Hi gang;
Here's another type of holder for the Makita-includes a dust skirt, vac attachment, and an LED ring light which is switch controlled;
LED runs on 12VDC- an old mobile phone adapter
gperzel
gperzel
Would you share the plans and the SVGs ? Thanks kind sir!gperzel wrote:Hi gang;
gperzel
Looking at this again, I think using M3 insertion nuts would be the hot ticket for under the magnets and will have to try that if I ever move on from the current version.
Do you have these in DXF still?
I never had them in DXF --- I only posted SVG, which is the original format, save for the .pdf which I made using Freehand and that source file (since I draw pretty much everything up in Freehand).
Will this mount fit the Shapeoko 2? Specifically, does it provide enough clearance at the top of the router? Planning on getting the Makita RT0701 as it seems to be one of the best spindles.
It would fit on a Shapeoko 2, but w/ the stock Z-axis configuration, would limit travel.
I have about 4.125" from the top of the top mount to the top of my router, and 6" or so from the top of the top mount to the tip of a very long endmill --- might be usable --- I'll try to find the time to dismantle my two machines this evening and try swapping things around.
Of course, one could just add a block or extend the mount a bit.
Here is my Makita RT0701 Mount and Dust shoe set up.. 1/2" Acrylic dust shoe with led strip to light up around the bit.
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
Upgrades
Damin69's Build Log
[quote="Damin69"]Here is my Makita RT0701 Mount and Dust shoe set up.. 1/2" Acrylic dust shoe with led strip to light up around the bit.
Did you mill the mount yourself?
Not the mount but i did the dust shoe.
Sent from my SM-G900R4 using Tapatalk
Shapeoko 2 #6971
Upgrades
Damin69's Build Log
Upgrades
Damin69's Build Log
