Is anybody running a Makita 0701 with the z-axis belt drive kit yet? I'm considering this for my spindle configuration, and I'm wondering how much of the work area is lost to the larger router body. I realize the belt drive z-axis allows the router to be mounted closer to the Z axis maker slide, and this should help.
I know Targus is considering this setup. Anyone else, yet?
Just ran my first milling job on my S02 today. I have over 200 signs to make this winter, so I am looking at a more robust spindle setup.
Makita plus Z-axis belt drive yet?
Re: Makita plus Z-axis belt drive yet?
The only work area which should be lost is at the back of the machine, a narrow strip defined by the difference in the location of the collet centers (left--right is limited by the X-axis gantry plate width).
If you use an efficiently arranged mount that distance should be about zero.
I lose a small bit of left--right travel on mine mounted on my SO1 'cause the vacuum hose is mounted on the left 'cause of the closed endplate design --- you should use a mount which hangs it off the front.
I have not had any problem yet using Targus's Makita Brackethttp://www.shapeoko.com/forum/viewtopic ... ta+Bracket
That being said. I am still waiting on the Belt drive kits to get in so that I can upgrade to the Nema 23 motor I have sitting on my shelf for the Z axis.
Shapeoko 2 #6971
Upgrades
Expanded to 1000 x 1800
Damin69's Build Log
Upgrades
Damin69's Build Log
I have a setup using my own variants of this. Using a belt driven Z-Axis and a Chinese 800w spindle. Pics towards the end of this post.
I am now able to recover 15mm of the stick-out that using a larger spindle (65mm dia) required to clear the original motor mount plate.
Having said that, I still have a reasonable amount of overhang at the front of the machine when the gantry is full forward.
If you extend your waste board, or just use a solid enough workpiece, it is possible to hang jobs over the front edge, provided they are well held further back.
I have thought about doing something to provide support at that front edge, but it is on my long list of tinkerings as yet!
Thanks for all the info, folks! I've just picked up the Makita and will go with Targus's mounts for now, and eventually the belt drive Z-axis.
I'd love to know how much Y you can get back with that and a mount change.
I'd have to change how I have my drag chain hooked up with it, but I guess it'd be worth it for the Y and the warm fuzzy feeling of the router being closer with its BFF, gantry.
