best tool for uk builds
nitromann14
Post by nitromann14 » Fri Apr 10, 2015 6:14 am
was looking at a dw660 but found out its a usa 120v machine so i cant ue it over here on 240v .
what is the best machine to use in the uk ??
thanks
Georgei
Re: best tool for uk builds
Post by Georgei » Fri Apr 10, 2015 8:11 am
The model numbers are different here in UK.
Have a look for the D26200 or the smaller new DW670.
The Bosch alternative is the GKF600.
In my machine I am using a Bosch POF500 which you can find cheap second hand on e-bay.
It hasn't got speed controller but I am using an external one bought on e-bay for £2 and works really nice with no problems.
Have in mind that all the above are noisy and you will need ear defenders when working with them.
George
bengtec
Post by bengtec » Fri Apr 10, 2015 4:56 pm
the makita rt0700 http://www.toolstop.co.uk/makita-rt0700 ... 40v-p63809 seems to be popular, and recently i started considering a kress 1050 (5k-25k rpm version) http://www.sorotec.de/shop/Spindle-Moto ... -230V.html as it has a wide range of collets available. the kress is a little more to start with, but if you add up the parts/shipping to get a 1/4" elaire collet for the makita shipped here from the US as well as buying the router they come out to about the same, I'm yet to decide.
Ben
Stock SO2 #7722, Dremel 3000, Arduino Uno, G-shield, GRBL 0.9g
Rhino>CamBam>Raspberry Pi with GRBLWeb
Post by cvoinescu » Fri Apr 10, 2015 5:08 pm
The Makita RT0700C is intended as a laminate trimmer (a small router). The Kress 800 and 1050 FME-1 are intended as a spindles, so I would say they are likely to be better suited than the Makita RT0700C. That said, the Makita is a very solid choice too.
Post by WillAdams » Fri Apr 10, 2015 5:32 pm
Marked out a sub-section on the wiki: http://www.shapeoko.com/wiki/index.php/ ... ons#Europe
If I had the choice, price not being a consideration, I'd take a Kress over a Makita:
- narrower shape, moves endmill closer to gantry to reduce lever effects
- no need to order a separate collet
- spindles are rated in working horsepower as opposed to peak
That said, here in the States it was much cheaper to get a Makita than a Kress, even after I added in the Elaire Corp. collet.
William
nitromann14
Post by nitromann14 » Wed Apr 15, 2015 6:58 pm
just managed to pick up a cheap Bosch POF500 on ebay for £30 so i think ill use that for a while ..i have spoken to the guys at inventables and i can get the spindle upgrade kit from them if i want to later on ..
george ..what do you think of the bosch and how it cuts etc ..any advice you can give on speed to run at etc .
thanks
Georgei
Post by Georgei » Wed Apr 15, 2015 7:27 pm
The POF500 has only one speed that is around 2700rpm (high for my liking).
So I bought from e-bay a very cheep speed controller like this one (http://www.ebay.co.uk/itm/Adjustable-Vo ... 566d4cf702)
It works extremely well with the pof500 and gives me a speed from 13800 to 27000rpm.
Usually I use the lower speed setting at around 13800 rpm (it is more quiet). If I see the cutter strangles I go a little higher.
But up to now I haven't gone more than half the speed. Also, even though that it runs in lower rpm I do not have any heating issues even after 3 continues hours of running.
For 3mm cutters (or 1/8") you will an adaptor (Have a look at e-bay). The available collets for the POF500 from Bosch are 1/4" , 6mm, and 8mm.
agibson
Post by agibson » Mon Apr 20, 2015 11:26 am
I don't suppose anyone has any experience of this trim router:
http://www.amazon.co.uk/Electric-Trimme ... 270&sr=1-5
http://www.amazon.co.uk/100365C-Electri ... B00VI70FR2
It looks very similar to the makita (I think even the font may be a copy?), is it worth a try?
I'll be upgrading from a dremel copy, so no idea what to look for spec wise?
Post by WillAdams » Mon Apr 20, 2015 11:53 am
Those are interesting. Look something like the plastic body of a Grizzle trim router which comes in two versions, one plastic body, the other metal.
While a step up from a Dremel / rotary tool, they'd probably be along the lines of a DW660, except w/ built-in speed control.
We discuss spindle specs on the wiki --- did you see this?
http://www.shapeoko.com/wiki/index.php/Spindle_Options
nitromann14
Post by nitromann14 » Mon Apr 27, 2015 6:35 am
ok so based on advice from you all i have got a Bosch POF500 router .im sure this will be fine to start with .
also ordered a speed controller to run it on so i can lower the speed if i need to ,yes i know i could have spent ore money on all this but the cost outways the benefits to start with so im happy so far
just got to wait until i get my invitation to order my mechanical e-shapeoko kit from ASL and then i can start building ..
