How to mount DW660?
Improbable Construct
Re: How to mount DW660?
Post by Improbable Construct » Thu Feb 07, 2013 12:48 am
I will try and post some G-code for these.
I might get to it tonight but it may be tomorrow before I can get it done.
You said that you would like to use a 1/8" two flute endmill. (That's what I use)
Questions:
1. Feed speed (I run 1500 mm/min with a DW660)
2. Plunge speed (I like to use 200 mm/min)
3. Depth per pass (I use 1/16")
4. Where would you like to start (I start in the middle but any corner is also possible)
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
Post by WillAdams » Thu Feb 07, 2013 3:36 am
Middle sounds fine --- not sure 'bout the rest, using a Dremel 4000, but will be able to adjust.
Trying to plot the G-code by hand, but am mystified by the circle code.
Post by Improbable Construct » Thu Feb 07, 2013 4:14 am
Ok here is the G-Code for a single DW660 mount.
It is set to MM measurement.
It assumes that you are starting in the center of a 100x100mm square of a 10mm thick material.
The feed speed is 500 mm/min with a 200 mm/min plunge. (This should work with a Dremel 4000 but still may be too fast)
1/8" 2 flute bit with a 1/16" pass depth.
There are 3D tabs built into the G-code.
This G-Code is for Mach3 but if it throws errors I have hundreds of post processors available, I just don't know which one will work with your setup.
Let me know how it goes!
100x100x10mm_DW660_Mount.txt
(11.1 KiB) Downloaded 228 times
Shapeoko 3 # 0003
Store:
Twitter:
Post by Improbable Construct » Thu Feb 07, 2013 10:33 pm
I cut some extra DW660 mounts this morning.
DW660 mounts.JPG (104.73 KiB) Viewed 3325 times
$13.00 a pair. Includes hardware and domestic shipping.
PM me or post in this thread if you are interested.
Shapeoko 3 # 0003
Store:
Twitter:
Post by WillAdams » Tue Feb 12, 2013 2:19 am
Didn't have much luck w/ your G-code IC, so tried hand-coding, w/ less luck.
Currently have:
Code: Select all
G17 (Select the XY plane for arcs)
(G20 After this, units will be in inches)
G21 (for mm)
G90 (Switch to absolute distance mode)
G0 Z5.0
G0 X0 Y-46.665
G01 Z-1.5 F250
G1 X9.525 Y-46.665
G3 X14.28 Y-41.91 I0 J4.75
G1 X14.28 Y-35.87
G1 X17.735 Y-35.87
G3 X21.097 Y-34.4775 I0 J4.75
G1 X38.2875 Y-17.287
G3 X39.68 Y-13.925 I-3.45 J3.4
G1 X39.68 Y41.91
G3 X34.925 Y46.665 I-4.75 J0
G1 X10.316 Y46.665
G2 X10.0 Y46.349 I-0.316 J0.000
G2 X9.684 Y46.665 I0 J0.316
G1 X-9.684 Y46.665
G2 X-10.0 Y46.349 I-0.316 J0.000
G2 X-10.316 Y46.665 I0 J0.316
G1 X-34.925 Y46.665
G3 X-39.68 Y41.91 I0 J-4.75
G1 X-39.68 Y-13.925
G3 X-38.2875 Y-17.287 I5.60 J0.375
G1 X-21.097 Y-34.4775
G3 X-17.735 Y-35.87 I4.75 J6.75
G1 X-14.28 Y-35.87
G1 X-14.28 Y-41.91
G3 X-9.525 Y-46.665 I4.75 J0
G1 X-0.0075 Y-46.665
G1 X-0.0075 Y-30.789
G3 X-4.1141 Y-26.078 I-4.75 J0
G2 X-19.2025 Y27.087 I4 J29.875
G3 X-17.47 Y30.751 I-1.7 J3.05
G1 X-17.47 Y35.98
G1 X17.47 Y35.98
G1 X17.47 Y30.751
G3 X19.2025 Y27.087 I5 J0
G2 X4.1141 Y-26.078 I-19.141 J-23.3
G3 X0.0075 Y-30.789 I0 J-4.11
G1 X0.0075 Y-46.665
G01 Z-3.0  F250
G1 X9.525 Y-46.665
G1 X14.28 Y-35.87
G1 X17.735 Y-35.87
G1 X39.68 Y41.91
G1 X10.316 Y46.665
G1 X-9.684 Y46.665
G1 X-34.925 Y46.665
G1 X-39.68 Y-13.925
G1 X-14.28 Y-35.87
G1 X-14.28 Y-41.91
G1 X-17.47 Y35.98
G1 X17.47 Y35.98
G1 X17.47 Y30.751
G1 X0.0075 Y-46.665
G01 Z-4.5  F250
G1 X9.525 Y-46.665
G1 X14.28 Y-35.87
G1 X17.735 Y-35.87
G1 X39.68 Y41.91
G1 X10.316 Y46.665
G1 X-9.684 Y46.665
G1 X-34.925 Y46.665
G1 X-39.68 Y-13.925
G1 X-14.28 Y-35.87
G1 X-14.28 Y-41.91
G1 X-17.47 Y35.98
G1 X17.47 Y35.98
G1 X17.47 Y30.751
G1 X0.0075 Y-46.665
G01 Z-6.0  F250
G1 X9.525 Y-46.665
G1 X14.28 Y-35.87
G1 X17.735 Y-35.87
G1 X39.68 Y41.91
G1 X10.316 Y46.665
G1 X-9.684 Y46.665
G1 X-34.925 Y46.665
G1 X-39.68 Y-13.925
G1 X-14.28 Y-35.87
G1 X-14.28 Y-41.91
G1 X-17.47 Y35.98
G1 X17.47 Y35.98
G1 X17.47 Y30.751
G1 X0.0075 Y-46.665
G01 Z-7.5  F250
G1 X9.525 Y-46.665
G1 X14.28 Y-35.87
G1 X17.735 Y-35.87
G1 X39.68 Y41.91
G1 X10.316 Y46.665
G1 X-9.684 Y46.665
G1 X-34.925 Y46.665
G1 X-39.68 Y-13.925
G1 X-14.28 Y-35.87
G1 X-14.28 Y-41.91
G1 X-17.47 Y35.98
G1 X17.47 Y35.98
G1 X17.47 Y30.751
G1 X0.0075 Y-46.665
G01 Z-9.0  F250
G1 X9.525 Y-46.665
G1 X14.28 Y-35.87
G1 X17.735 Y-35.87
G1 X39.68 Y41.91
G1 X10.316 Y46.665
G2 X10.0 Y46.349 Z-7.5 I-0.316 J0.000
G2 X9.684 Y46.665 Z-9 I0 J0.316
G1 X-9.684 Y46.665
G2 X-10.0 Y46.349 Z-7.5 I-0.316 J0.000
G2 X-10.316 Y46.665 Z-9 I0 J0.316
G1 X-34.925 Y46.665
G1 X-39.68 Y-13.925
G1 X-14.28 Y-35.87
G1 X-14.28 Y-41.91
G1 X-17.47 Y35.98
G1 X17.47 Y35.98
G1 X17.47 Y30.751
G1 X0.0075 Y-46.665
which seems to work, except 2 out of 3 times, the gantry goes crashing into one corner, even after testing and zeroing it w/:
Code: Select all
G21 (for mm)
G0 X0 Y-50
G0 X50 Y-50
G0 X50 Y50
G0 X-50 Y50
G0 X-50 Y-50
G0 X0 Y-50
G0 X0 Y0
Tried to find a specific set of settings to cut HDPE w/o any success. Did eventually manage to begin a cut, but it kept drifting on the Y-axis, resulting in staggered cuts --- speeding up the dremel seemed to help, but I finally had to kill the job and call it a night.
Any thoughts /suggestions?
AngusF
Post by AngusF » Tue Feb 12, 2013 1:23 pm
Try a shallower cut. Drifting is the result of missed steps, which typically happen when the spindle can't keep up with the demands of the job. As the spindle speed goes down, the stepper torque needed goes up.
For example, with an 1/8" end mill cutting Baltic birch plywood at a 0.7mm depth per pass, I will miss steps at 800mm/min, but not at 700. I'm still using the stock spindle, but it's feeling pretty used up. I have a DW660 on the way. I expect it'll help considerably.
Post by WillAdams » Tue Feb 12, 2013 2:17 pm
Thanks! I'll pull back to 1mm and if that doesn't work, will go down to 1/2mm.
Took the liberty of adding your information 'bout Baltic birch to the Materials page in the wiki 'kay?
William
lobos450
Post by lobos450 » Wed Feb 20, 2013 1:48 am
Any mounts left IC? I'm interested if there are.
Post by Improbable Construct » Wed Feb 20, 2013 2:22 am
PM sent.
Shapeoko 3 # 0003
Store:
Twitter:
zapmaker
Post by zapmaker » Sat Mar 02, 2013 9:24 pm
The line N110G71G91.1 near the top of IC's file is the problem. You need to remove G91.1 (i.e. change to N110G71) for Grbl to behave correctly. Without the change, I saw was the spindle move down to lower left exceeding the bounds of the available area. Tested with Grbl 0.8c.
Shapeoko #668
Dual-Y axis, belts outside, DW660 | Author of Grbl Controller 3.0 | http://zapmaker.org
