My MBE Extruder Build Log (was Eye candy...)
deejayspinz
Post by deejayspinz » Sat Jan 19, 2013 9:22 pm
Putting the bits together.... Any guesses?
Re: Eye candy...
Post by WillAdams » Sun Jan 20, 2013 2:11 pm
Control board for a 3D printer?
deejayspinz
Re: Eye candy...
Post by deejayspinz » Sun Jan 20, 2013 3:30 pm
Yep... Now have most of the extruder wired up.. Will be following this approach using Mach3...
Have to complete:
- SSR's for extruder and bed heater
- finding suitable power supply to heat the extruder and bed.
- cutting a mounting bracket for the Z axis. Want to have something I can quickly swap between my DW660 and this.
- software tuning (Mach3/Slic3r)
deejayspinz
Re: My MBE Extruder Build Log (was Eye candy...)
Post by deejayspinz » Fri Jan 25, 2013 5:01 pm
DW660 Mount cut with extension to hold printer. Will be looking for a way to convert the 3x M5 bolts to some sort of quick release system.
2013-01-25 ShapeOko3DPrinterMods 001 1024.jpg (169.67 KiB) Viewed 4051 times
Post by cvoinescu » Fri Jan 25, 2013 5:18 pm
I feel that that's way too flexible for the extruder. I have a much more rigid metal bracket; the extruder, with its fairly heavy motor, wobbles significantly when the Y moves jerkily. This results in wavy surfaces on the prints. I can't help but feel that this is going to be worse.
deejayspinz
Post by deejayspinz » Fri Jan 25, 2013 5:31 pm
cvoinescu wrote:I feel that that's way too flexible for the extruder. I have a much more rigid metal bracket; the extruder, with its fairly heavy motor, wobbles significantly when the Y moves jerkily. This results in wavy surfaces on the prints. I can't help but feel that this is going to be worse.
When I finally get around to printing, I'll keep an eye out for this. I don't expect to be flying around with significant speeds, so I don't there being too much jerking. Nor do I think my extruder (and Nema17) are that heavy.
Edit: One thing I forgot to mention is that I have both the dual "Y" motor mods, as well as dual X MakerSlide. Both are Nema 23's as well. So, the gantry is pretty stiff.
roberlin
Post by roberlin » Sat Jan 26, 2013 12:21 am
If the bouncing ends up being a dealbreaker, you might try a Bowden-tube version.
Bart has made a QU-BowDen and promises source files soon (in the Delta Bot ORD thread at buildlog).
deejayspinz
Post by deejayspinz » Sun Feb 03, 2013 12:39 pm
Its working!
Sent from my thingamabobber tablet using Tapatalk
deejayspinz
Post by deejayspinz » Sun Feb 03, 2013 12:54 pm
More... Boring, but im excited. Srry.
Post by WillAdams » Sun Feb 03, 2013 1:49 pm
Very cool! Looking forward to a write-up on the wiki --- I really want to have printing functionality on my unit before my summer vacation.
The dual-functionality is very appealing --- would there be an advantage to / possibility of using both tools simultaneously? That'd help make up for the loss of working area. Perhaps using a cutter to machine / reach under overhangs?
Alternately, have you considered some sort of sliding dovetail quick release toolchange system?
William
