I use a Mk2b, basically this one.
http://www.ebay.com/itm/MK2B-12-24V-Hea ... 4d1e800f7f
Shapeoko <--> 3D Printer
Re: Shapeoko <--> 3D Printer
Has anyone tried the silicone heated beds?
For that Mk2 PCB bed, do you just solder the wires/thermistor on and then stick a plate of glass on top for your print surface?
Yes, you screw the PCB in place, and put a piece of glass on top of it. The bed needs to be very accurately parallel to the X and Y axes. Most people use springs, not spacers, on the screws holding down the bed. This means you can adjust the height of each corner by turning the screw.
Many people use foldback clips to attach the glass to the PCB. You don't solder the thermistor, you just run the wires for it underneath the PCB and place it in the hole, in contact with the glass, perhaps with a tiny dab of thermal grease. Some people put thermal insulation under the PCB.
So if I understand correctly is it something like this? Sorry if its messy.
- Attachments
- Section View Heated Bed.PNG (101.45 KiB) Viewed 2718 times
Yes, perfect.
I'm looking forward to reading more about this down the road as you get the project started.WillAdams wrote:I've drawn up something a bit different for the SO3 but still trying to puzzle out dimensions.
Rick
Machines Make My World!
Inventables X-Carve (Shapeoko 2.5) -- Mid-May
MakerFarm Prusa i3v 12"
Harley Davidson Heritage Softail
I am genuinely interested in how you get it to work.
I am planning on a supersize (1200x2200)mm Shapeoko As long as the usable table size is 1000x2200, I figure I'll do a novel Z axis idea of moving the table instead.
