Change tool & tool length compensation
Hi,
after some days fighting with mach3, i need help with this if it's possible...
Firs of all, thank you for any tips you could give me...
- Is it absolutely necessary limit switches for a change tool procedure?? now i havent' got installed, now i'm working with soft limits.
- Now i know how i have to do to change tool when the mill is exactly the same length, but my problem is when the tool is different length.... i was looking information in mach3, and i finished in a offset you have to mark in each tool you have in mach3,so
Anybody has done this procedure???? Could you explain me the process??
Probably i need a probe to the Z axis, isn't it??
Thanks in advance...
Re: Change tool & tool length compensation
I do not have any limit switches installed in my setup, so no you do not have to have them.
I don't even have soft limits set.
I let the CAM software take care of the tool offsets.
As far as Mach3 is concerned every tool is tool #1.
I break my G-code up into sections based on the tool.
It is not unusual for me to have 5-10 G-code files for one part.
A touch probe for the Z-axis is the easiest way to reset after a tool change.
It is a pain to set up but once its done you don't have to change it again.
If you want I can send you the screen set I use. It should have touch probing set up for mm units.
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
Shapeoko 3 # 0003
Store:
Twitter:
Hi IC,
so if i understand right, you break you G-CODE file, you mean, you have separate files and you load each once a time in the mach3??? so if yes, how you homing X,Y when you load a new file??? with a mark?? o how?? because you should start in the same position you started the first time, no??
When you refere to a screen set you mean BlueScreen plugin for mach 3, isn't it?? that's i've got installed....
Thanks again!!!!
Thanks again!!!!
Right, I break up my G-code.
So I might have a file that pockets an area with a 1/4" endmill.
Then I might have to change to a 1/8" endmill and finish the pocket.
Then I may have another file that cuts some holes.
Then another one that cuts the outside profile.
Before I start I decide where 0,0 will be. Maybe it is the center maybe it is a corner.
Once you tell Mach3 where that is and zero out x and y, Mach3 will remember where that point is as long as you do not unlock your motors.
If you hit reset or your E stop then it all falls apart...
You can load new G-code and Mach3 will start from the same point.
From there you can swap tooling and all you have to do is reset your Z zero.
I do use the MachBlue with probing screen set.
Shapeoko 3 # 0003
Store:
Twitter:
Shapeoko 3 # 0003
Store:
Twitter:
OK IC, i'll try to do it in that way....
Thanks again
Thanks again
Someone should really do a video on a tool change with a grblShield
cant find anything that I can relate to
This video covers a basic (manual) method to this, using a stock shapeoko2(grbl and dremel), makercam, and ugs. Of course having homing switches installed would make things even easier.sectorix wrote:Someone should really do a video on a tool change with a grblShield
https://www.youtube.com/watch?v=qf-EAbFD11s
Hi,
you don't need to split up your G-Code - just insert a tool change command.
There are several ways to do this - but for manual changes this will do:
The tool change itself with tool length compensation works this way:
Christian
Code: Select all
M05
M00
M03
- M05 stops the spindle (if it is controlled by Mach3)
- M00 stops the machine so you can change the tool
- M03 restarts the spindle
- After M00 stopped the machine you can move it manually to any position you like so you can release the old tool...
Don't worry about changing the position - the machine will later automatically return to the right position... - Insert the new tool...
- Finally touch the Z-Axis off with the new tool against the same surface you used to touch off the old tool -> tool length is now compensated.
- Continue the program...
Christian
Hello Christian,Estlcam wrote:Usually your CAM program should do this for you automatically if you use more than one tool.
The tool change itself with tool length compensation works this way:You don't need limit switches for manual tool changes. They are only necessary if you have an automatic tool changer / automated tool length sensor or if you expect the machine to return to a dedicated "home" position for changing.
Don't worry about changing the position - the machine will later automatically return to the right position...- Insert the new tool...
Christian
I am a newbie Estlcam user
For M00 and M06(tool change), what is the difference of them actions?
I thought M06 is the manually bit-change command.
Thank you, Okinawanwinds
I do not have any limit switches installed in my setup, so no you do not have to have them.nio wrote: ↑Sun Mar 24, 2013 12:16 pmHi,
- Now i know how i have to do to change tool futuristic clothing when the mill is exactly the same length, but my problem is when the tool is different length.... i was looking information in mach3, and i finished in a offset you have to mark in each tool you have in mach3,so
