Openbuilds opinions
Openbuilds opinions
I have been looking around a lot on openbuilds, mostly at the larger format OX machine, as well as their version of "v rails".
Who here has first hand experience with these rails and wheels system? How is it compared to the Shapeoko?
I really want to build a sturdier and larger platform and have been finding that maybe a different extrusion/vrail type system would be better.
Re: Openbuilds opinions
No experienced here, but I watched the build video about a week ago and it does look like a pretty impressive machine.
The use of solid v-wheels should be less prone to compression, the quantity of wheels used, and the belt positioning using the solid wheets as the idlers is also a neat idea. The Z axis also appers to be very close to the X, which should help to limit flexing. I also like the way the structural members position themselves off the implicit size of other members (extrusions butted/accross/against other extrusions) which should help to make it easier to get a square, level build.
I almost ordered some of the parts for a 1.5M x 1M build last weekend. My head said yes, my bank account said no!
Dennis
Dennis
For the latest iteration of my shapeoko I ditched makerslide for the most part and moved to openbuilds v-rail mounted on hfs5-4040-600 for x and y. Very happy with the outcome. Stiffer than makerslide ever could be. No real downside other than clearance between the motor plates and the rail - button head screws are a fix for this. And the inventables wheels are 100% compatible with openrail.
akhlut wrote:For the latest iteration of my shapeoko I ditched makerslide for the most part and moved to openbuilds v-rail mounted on hfs5-4040-600 for x and y. Very happy with the outcome. Stiffer than makerslide ever could be. No real downside other than clearance between the motor plates and the rail - button head screws are a fix for this. And the inventables wheels are 100% compatible with openrail.
So you went with the rail only bolted into a misumi extrusion? Why did you pick this over the openbuilds "V rail extrusions"
Do you think the openbuilds rail extrusions themselves are of the same quality or better than the makerslide?
I have also gone with openrail on the X and used the HFS5-4060-1000, it has been great. Im very happy with it. Im also using the inventables v wheels. Quality is great on the openrail. I think it is much more ridged now on the X VS 2 pieces of makerslide with a 20x40 piece of extrusion sandwiched in between.
Shapeoko 2 #3920. Nema 23's. Belt drive Z axis, ACME rod upgrade,
1m rails on X and Y, X upgraded to 60x40 extrusion with openrail, Mid span supports,
DW660 with Super-Pid, IC's DW660 dust shoe.
Build Log
Build Log
Would you be able to post some pics of this? Im especially wondering how the spacing looks with the 40x60 extrusions. Any pics you have would be great.groguard wrote:I have also gone with openrail on the X and used the HFS5-4060-1000, it has been great. Im very happy with it. Im also using the inventables v wheels. Quality is great on the openrail. I think it is much more ridged now on the X VS 2 pieces of makerslide with a 20x40 piece of extrusion sandwiched in between.
If you take a look at my build log I go into detail with pics.awesomename wrote:Would you be able to post some pics of this? Im especially wondering how the spacing looks with the 40x60 extrusions. Any pics you have would be great.groguard wrote:I have also gone with openrail on the X and used the HFS5-4060-1000, it has been great. Im very happy with it. Im also using the inventables v wheels. Quality is great on the openrail. I think it is much more ridged now on the X VS 2 pieces of makerslide with a 20x40 piece of extrusion sandwiched in between.
Build Log
Build Log
Yes. I bolted http://openbuildspartstore.com/openrail-black-anodized/ onto a piece of 4040 extrusion.
http://i.imgur.com/FXP0pam.jpg
But now that I think about it you're referring to v-slot, and not openrail (I think of it as v-rail).
As far as the http://openbuildspartstore.com/v-slot-20-x-20mm/ I'm not sure as I haven't used it. My concern with it would be keeping debris away from the wheels, but if you add some debris guards and some sweepers to cut down on dirt I don't see why not. And I can't see why it wouldn't be of the same quality as makerslide. Everything I've ever bought from openbuilds has bee first rate.
I'm not sure why the debris issue would be any better or worse with the slot than with the rail. The slot is open at the bottom, so debris has a place to go.akhlut wrote: But now that I think about it you're referring to v-slot, and not openrail (I think of it as v-rail).
I've got a length of the 2020 V-slot that I'm going to put to use as an overhead hose support track in my enclosure. That can't really be compared to gantry axis applications, though, so I probably won't be able to provide relevant feedback.
I'm using their now-discontinued hardcoated OpenRail on my 1000 x 500 ShapeOko, and I've been very happy with the quality of their products and customer service. I had some issues with tolerances on some steel wheels (too tight, I crushed bearings during assembly), and they took good care of me.
This came up before on buildlog.net. In short, what I said was that V-slot was more versatile, and MakerSlide more rigid.
