Hi ,
I was testing out my Shapeoko last week, one of the tests I did was carving a 3d model. The process took around 2.5 hours of work to be done, would the default tool included in the full kit handle such long jobs?
I purchased 1/8" with 1/4" head (straight/round/ and v bits ) from mlcs (http://www.mlcswoodworking.com/shopsite ... its_anchor). I am using them with the default rotary tool included, wood this tool be able to handle those ones? My settings are as follows:
pass depth: 0.05 inch
feed rate: 30 inch/min
Running long jobs using default shapeoko rotary tool
Re: Running long jobs using default shapeoko rotary tool
Yes, it'll handle such jobs until it dies.
The problem is that will necessarily be during a job.
Don't risk it w/ expensive material.
I also seem to recall that people have had issues with the collet loosening during long jobs which causes the tool to get pulled out into the workpiece.
I can personally attest to this, even on some short jobs. I tried 3 different collets and cranked them down as hard as I could. The only way I could combat it was to use painfully slow feed rates or to add tape to the shank to get better grip. The tape option is a safety hazard, so I only did it for confirmation of the collet slipping.twforeman wrote:I also seem to recall that people have had issues with the collet loosening during long jobs which causes the tool to get pulled out into the workpiece.
I tried switching to a Bosch Colt but quickly abandoned it for several reasons:
- The deflection on the Z axis was too much for my liking due to the increased weight of the spindle, the need to move the spindle mount to the bottom set of holes, and shifting the bottom set of V-wheels up to the middle grouping of holes due to the mount's position
- The Precise Bits collets are hit or miss because of bad QC on Bosch's end
- It was as noisy as the default spindle
- The mess made from the downward air vent coated my work area in dust, despite of my best attempts to keep on it with a vacuum and dust separator
Fl0yd
Yep, had that one yesterday doing a 15 minute job. What would be a suitable feed rate for this? I've changed the settings to have less pass depth (0.04 inch) and feed rate of 30 inch per minute and used a brand new bit to be able to complete it. Should I lower the feed rate to be less? maybe something like 20 inch per minute? I've ordered some 3.2mm straight and round bits from ebay but they wont arrive soon so I have to work with the ones I havetwforeman wrote:I also seem to recall that people have had issues with the collet loosening during long jobs which causes the tool to get pulled out into the workpiece.
Why is the tape a safety hazard? it sounded like a good idea.fl0yd wrote:The only way I could combat it was to use painfully slow feed rates or to add tape to the shank to get better grip. The tape option is a safety hazard, so I only did it for confirmation of the collet slipping.
I don't seem to have issues using small bits. I've used a dremel 3.2 diameter with 2.4mm ball for a 2 hours job yesterday. Unfortunately I couldnt find one with 3.2 mm carving diameter at my local store.
