Another Red Shapeoko
Re: Another Red Shapeoko
Post by cvoinescu » Wed Sep 26, 2012 11:33 pm
What kind of laser is that?
Post by edwardrford » Thu Sep 27, 2012 1:22 am
cvoinescu wrote:What kind of laser is that?
and more importantly: Can it safely be mounted on my sharks?
Mudshark
Post by Mudshark » Thu Sep 27, 2012 2:13 pm
It is a 445nm (Blue) M140 in an Aixiz mount, same as jhilt67 identified. I used the DeWalt 660 mount to attach it to my pond Koi.
Released under Freedom of Information Act @2012
Killer Koi Attacking.jpg (45.97 KiB) Viewed 2834 times
Mudshark
Serial #0054, 2 Watt laser, dual X motors, double Y, ACME Z Axis, G540, Mach 3, rotating axis, needle cutter, Proxxon, 750mm x 375mm, laser cross hairs, auto zero, GT2
Ordbot #201, E3d hot end, bourdon tube feeder.
JuKu
Post by JuKu » Thu Sep 27, 2012 2:37 pm
Mudshark wrote: My best advice is to get a decent pair of laser safety glasses before using, it is easy to sunburn your retina even when being cautious.
don't look into a laser with your remaining eye!
Mudshark
Post by Mudshark » Thu Sep 27, 2012 6:41 pm
Is there a Wiki for self-Lasik? :lol:
Mudshark
rpe
Post by rpe » Fri Sep 28, 2012 4:40 pm
I would like to see a video of your laser in action.
Mudshark
Post by Mudshark » Sun Sep 30, 2012 2:57 pm
rpe wrote:I would like to see a video of your laser in action.
Hi RPE, Here's a short video that I hope gives you an idea.
http://youtu.be/AK45Ec7LDzA
(DSCF0555)
Just a quick burn on some cork to show it run. Interesting to see it thru the camera vs. glasses.
Mudshark
rpe
Post by rpe » Sun Sep 30, 2012 3:06 pm
I made one of those from blue ray 12x laser but it would not burn that fast. I can't remember what the NM's was.
Mudshark
Post by Mudshark » Tue Oct 23, 2012 3:02 pm
Added new belt clamps, a bit cleaner looking. Made with 1/2" Starboard. All friction fit to the angle brackets, pretty happy with them so far.
Belt clamp
Installed belt clamps on fixture.
Mudshark
Mudshark
Post by Mudshark » Wed Oct 24, 2012 9:58 pm
Here's some GCode files for the 1/2" clamps. Review them and edit as necessary for your use.
BELT CLAMP 4L for 12.7MM material.txt
(5.93 KiB) Downloaded 146 times
BELT CLAMP 4R for 12.7MM material.txt
(4.86 KiB) Downloaded 144 times
Mudshark
