error 5 serial port resource
JOJOVID
Post by JOJOVID » Sat Oct 12, 2019 3:47 pm
I’m getting an error 5 serial port resource? I’ve tried to carve files from both 9.5 and 10 with the same results. When I set the xyz (used the probe and paper trick ) I get the same results. It starts trying to carve starting on the Z 0 point. I shut down right away. Don’t know what to do? Anyone know what’s going on?
Re: error 5 serial port resource
Post by WillAdams » Tue Oct 15, 2019 9:38 am
Usually that's caused by EMI, see: https://wiki.shapeoko.com/index.php/Ele ... mendations
Contact us at support@carbide3d.com and we'll do our best to help.
JOJOVID
Post by JOJOVID » Sun Oct 20, 2019 2:39 am
Thanks, been out of business for 2 weeks trying to fix this. I heard also that it could be the USB cable, is that just a printer cable?
Post by WillAdams » Mon Oct 21, 2019 2:45 am
Yes, the USB cable is an ordinary one, USB A--B as one would use for a printer.
Usually we provide a very good quality one with ferrite beads:
https://www.amazon.com/Tripp-Lite-Hi-Sp ... B008VOPCGY
If you continue to have difficulty, contact us at support@carbide3d.com
JOJOVID
Post by JOJOVID » Wed Oct 23, 2019 2:46 am
Well after giving it 2 weeks to rest up, the machine is working great again. Thanks for your help.
