toolpath setting idea in Carbide Cut
DianaB
Post by DianaB » Fri Nov 08, 2019 8:24 pm
New here, just bought a used Shapeoko XXL. I have been looking through a ton of videos and reading a bunch and now I have a question. I stumbled over a YouTube video about not spoiling your spoil board. The gentleman has a different machine and thus different software but I need some help with applying the concept to the Shapeoko.
His concept was set the max z direction to the spoilboard then no matter what your machine will cut all the way through the material and not cut up the spoilboard. He accomplished it this way.
Set the bit on the spoiloard and have the value = to the max (-) value of the material. So if you are working with 1/2" block of wood you would put the tip on the spoilboard and set the z to (-.5). I think alternatively you could set it to 0. This way if there is a variance in your material you can set your depth of cut to .57. but the machine will never go past the Z set point.
So I get the concept what I don't know is how to achieve this. Carbide Cut asks about top or bottom. I guess what I really need to know is how can you set a max Z no matter what you say the depth of the material is to account for a variance in material?
Not sure if it makes any sense but here is the video https://www.youtube.com/watch?v=Q-Q1o16Ux-I
Diana
Re: toolpath setting idea in Carbide Cut
Post by WillAdams » Sun Nov 10, 2019 2:28 pm
That's a really good idea --- you'd just need a way to ensure that the endmill stickout is consistent with that setting.
DianaB
Post by DianaB » Sun Nov 10, 2019 7:14 pm
I did get the concept to work and posted a followup new thread. I am not quite sure what you mean when you say make sure the endmill stickout is consistent with that setting? I was not able to set a -Z in Carbide Motion as far as I could tell so I ended up setting a higher Z value than my material and it worked. My material was .47 inches and I set my Z to .51. Cut through and never touched the spoilboard.
northbear
Post by northbear » Thu Nov 14, 2019 10:57 pm
Can the same effect be done by setting z-zero at your waste board and defining zero at the bottom of the stock in job setup in Carbide Create?
My buildlog is here
northbear
Post by northbear » Mon Nov 18, 2019 7:25 pm
Quick note to say I tried setting z-zero at the waste board and defining zero at the bottom of the stock in job setup in Carbide Create and it seemed to work great. Only did a quick test but thought I would report back
My buildlog is here
DianaB
Post by DianaB » Wed Nov 20, 2019 8:34 pm
I will try that. I think I did and couldn't get it to work but I will review it and try again.
