Just built my Shapeoko XXL. Everything seems to be working right as I have cut a few items.
The one thing that does not seem right is when the machine is homing.
As an example if I have everything set to the center point and activate homing, the Z axis
does it's double movement, The Y axis goes to the back of the machine, and X moves right.
When X gets to the right, the switch closes, than backs off. The Y closes as the stepper
buzzes for a couple of seconds and then backs off and opens the switch.
If I operate the Y switch before it reaches the back and hold it closed, X homes and everything
stops without the buzzing. I placed a wood block next to the belt so the Y will close before
reaching the back of the track it still buzzes and then backs off.
Is this normal?
Thanks for any help you can give me.
Norm
Y axis homing
Return to “Shapeoko 3 Assembly”
Jump to
- General Discussion
- ↳ Discussion
- ↳ For Sale
- ↳ Lounge
- Get Help!
- ↳ Shapeoko 3 Assembly
- ↳ Assembly
- ↳ Software - CAD, CAM, Workflow Help
- ↳ CAD Help
- ↳ CAM Help
- ↳ Electronics
- ↳ GRBL
- ↳ LinuxCNC
- ↳ Mach3
- ↳ tinyG
- ↳ Netduino
- ↳ PCB Fabrication
- ↳ MakerCAM
- ↳ TB6560 Driver Board Help
- ↳ Geckodrive
- ↳ Computing Hardware
- Spindles, Cutters, Etchers
- ↳ Trim Routers
- ↳ Mini Spindles - Purchased
- ↳ DIY Spindles
- ↳ Rotary Tools (like dremel)
- ↳ Other - (etchers, drag knifes, lasers)
- ↳ Pick and Place!
- ↳ Tooling & Fixtures
- Design Ideas
- Member Projects
- Build Logs
- 3D Printing
- Website
- ↳ Site Suggestions
- ↳ Site Problems
