I have recently built a Shapeoko 3 XL with Z+. The included dust boot fits fine on the Dewalt but is too small on the Makita, the other issue with this boot is that it is not independent of the Z axis and did cause an issue which I suppose would have been obvious to more experienced CNCer.
I have been looking for a supplier of a dust boot system that is independent of the rising and falling of the Z axis. During investigation I found two suppliers "Suckit" and "PWNCNC", Suckit no longer supply a dust boot option for the Shapeoko 3 leaving just PWNCNC which is Stateside (I'm in the UK)
Does anyone know of an alternative to PWNCNC I'd like a couple of different options and have no issues buying from the US but can be costly due to import taxes that are added when arrived in the UK.
TIA
Dust Boot
Return to “Shapeoko 3 Assembly”
Jump to
- General Discussion
- ↳ Discussion
- ↳ For Sale
- ↳ Lounge
- Get Help!
- ↳ Shapeoko 3 Assembly
- ↳ Assembly
- ↳ Software - CAD, CAM, Workflow Help
- ↳ CAD Help
- ↳ CAM Help
- ↳ Electronics
- ↳ GRBL
- ↳ LinuxCNC
- ↳ Mach3
- ↳ tinyG
- ↳ Netduino
- ↳ PCB Fabrication
- ↳ MakerCAM
- ↳ TB6560 Driver Board Help
- ↳ Geckodrive
- ↳ Computing Hardware
- Spindles, Cutters, Etchers
- ↳ Trim Routers
- ↳ Mini Spindles - Purchased
- ↳ DIY Spindles
- ↳ Rotary Tools (like dremel)
- ↳ Other - (etchers, drag knifes, lasers)
- ↳ Pick and Place!
- ↳ Tooling & Fixtures
- Design Ideas
- Member Projects
- Build Logs
- 3D Printing
- Website
- ↳ Site Suggestions
- ↳ Site Problems
