After selling a number of extruder setups and a couple dozen full printers of various styles, some have chosen to purchase a hotends.com hotend clone from ebay. At the request of a local who wanted to cut a few corners, I ordered and installed a $36 clone from ebay. They are similiar in build but do NOT perform the same. I have built enough printers to solidly say that the $30 discount is not worth the headaches.
Enough so that I went out of pocket at a loss of $70 and bought the customer a replacement hotend before even delivering his custom printer. To each his own but I thought it only fair to give this notice. The money you save on a cheap hotend will cost you time , aggravation and filament. Please dont purchase a mk4 or mk5 clone on ebay
Don't buy this hotend
Re: Don't buy this hotend
I second that. A fraction of them may be good, but hotends.com and the authorized resellers are the way to go. Generally speaking, if it's a new Mk IV on eBay, or if it comes with a 1.75 mm "conversion kit", it's almost certainly bad. If it's touted as a Mk V, check these tell-tale signs.
The original J-Head Mk V and Mk VB:
Here's a sample from an eBay seller, claimed to be a J-Head Mk V, which fails on all six counts. I've also seen absurdities such as "All in one GENUINE J-HEAD set Original Improved Design", "UK made all-in-one J-HEAD set ! Original Design!", and "All in one GENUINE J-HEAD set for RepRap Made in theUK" [sic].
On the other hand, this one may well be the real thing, although it's hard to tell.
- is made of brass (yellow), not aluminum (white);
- does not have a nipple at the tip of the nozzle;
- has a fairly shallow shoulder at the base of the nozzle cone;
- does not have a grub screw;
- has five grooves on the PEEK part, not four;
- has nicely, cleanly machined grooves in the PEEK part.
The one in the pic is exactly the clone I have. It is a waste of money. To add to the notes listed. The inner hollow setscrew is an oddly larger size which does not allow for a teflon insert so there is an open cavity for the filament to deform causing jams. If using a bowden line like is needed for a rostock, this also means no chance of retraction to change colors as the filament swells in this cavity and will not draw back into the line.
The easiest thing to tell is the number of slots in the peek is 4 then its fake. Apparent in most photos. If the hotend is too wrapped up in tape to count the slots then don't buy a hotend from that moron either even if he has the right parts as he has taped over all venting. (http://www.amazon.com/JMT-Printer-0-35m ... ead+hotend)
I get my hotends from Makerfarm.com or 3dmakerworld. Both arrive very quick in the US (2 days).
