ShapeOko inspired CNC by Northbear
northbear
Re: ShapeOko inspired CNC by Northbear
Post by northbear » Fri Dec 20, 2013 3:03 pm
LTMNO wrote:Very Nice looking machine... well done!
Thanks! I have to say the extruded aluminum bed on your build (http://www.shapeoko.com/forum/viewtopic ... =80#p17942) is impressive!
My buildlog is here
LTMNO
Post by LTMNO » Mon Dec 23, 2013 1:21 am
Thanks. Haven't been able to use it yet. Will do after the holidays. I bought clamp downs from amazon. Wrong size. Need to build some custom clamps. :-(
northbear
Post by northbear » Tue Apr 28, 2015 1:36 pm
Had a question on the settings for my electronics some of which I had listed http://www.shapeoko.com/forum/viewtopic.php?f=34&t=2119 so I thought I would add post here so I could find it again if needed
As a reminder, I am using individual singe axis TB6560 drivers from e-bay with a breakout board with LinuxCNC. The motors on x and y are NEMA 23 57BYGH104 from Circuit Specialists and the Z axis is NEMA 17 25253-01 from Inventables.
On the drivers I am using the following settings:
driver settings.PNG (9.95 KiB) Viewed 4535 times
In LinuxCNC The step and direction settings are:
step and dir.PNG (3.04 KiB) Viewed 4535 times
I measured my Jitter as 25000 (don't just use this value! measure it for yourself when using LinuxCNC!)
On my Breakout board I wires as shown below: the "My breakout board" column is what is labeled on the board itself and the "Mill" column is what I setup in LinuxCNC.
My buildlog is here
northbear
Post by northbear » Tue Apr 28, 2015 1:39 pm
And here is some mechanical setup information for my own reference
work area.PNG (10.87 KiB) Viewed 4534 times
My buildlog is here
northbear
Post by northbear » Wed Jan 27, 2016 9:56 pm
Replaced the breakout board which went bad. More information here: http://www.shapeoko.com/forum/viewtopic.php?f=4&t=7499
My buildlog is here
northbear
Post by northbear » Sat May 26, 2018 3:21 am
Been a while since I have posted, but recently I made a few updates to my CNC.
First update was to my dust shoe.
My first dust shoe was never really designed to be permanent and was showing it's age (aka falling apart!). I have also always liked the idea of fixed z height dust boot so I designed one up quite a while ago and finally got around to building it! Sheet metal part was made by a fab shop friend, the tube, adjustable teardrop handle and brush were purchased and all the other parts were made by me on the CNC (with help from the drill press and table saw).
Tube clamps were made on the CNC out delrin. Holes were drilled in the end and side with the drill press and tapped to a M5 thread by hand
Clear lexan piece was made on the cnc and used LOCTITE® PLASTICS BONDING SYSTEM http://www.loctiteproducts.com/p/sg_pls ... System.htm to attach the brush (actaully a door sweep) to the lexan.
I have used it just a couple of times but it seems to work well. Maybe seals a bit *too* well in that it almost suctions down to the workpiece.
Second update was to add a z axis touch off plate.
I *really* like it. As I am using LinuxCNC I followed the guide here - http://7xcnc.com/software/probing/z-touch-plate/ Only changes I made from the directions were to add G20 to the beginning of the 100.ngc code, changing so the units to inches and setting the correct distance for the touch off plate. (see code below)
<pre>
o100 sub
G20
( Set current Z position to 0 so that we will always be moving down )
G10 L20 P0 Z0
( Probe to Z-10 at F25 [Uses machine units, I work in mm, this is meant to be slow!] - CHANGED MINE TO INCHES -  )
G38.2 Z-.5 f.8
( Set Z0 at point where probe triggers with offset of +1.47 [this is the thickness of my PCB plate. You must adjust this for your plate / setup] - CHANGED MINE TO MEASURED PLATE THICKNESS IN INCHES)
G10 L20 P0 Z0.591
( Rapid up to Z10 above the material - AGAIN CHANGED MINE TO INCHES AND MADE LARGER SO IT WOULD BE ABOVE THE PLATE)
G0 Z.75
o100 endsub
</pre>
I sanded the plating off an old heatsink (the plating was not conductive) to use for the tool touch off and used a bolt and a magnet with a c'sunk hole to attach to the nut on the router.
Pictures below probably better show the upgrade.
My buildlog is here
northbear
Post by northbear » Sat May 26, 2018 3:25 am
Couple pictures of the touchoff plate, linuxCNC button (upper right hand corner), as well as a picture of my grounding wire on the inside of the tube. Have had trouble with static in the past so wanted to try to prevent static buildup.
My buildlog is here
Johnywalter
Post by Johnywalter » Fri Jun 01, 2018 11:02 am
@northbear
With one drill press you use?I mean model.
This so accurate.Must be something good and quality for this work. ;)
Jon
My masterbuilt smoker reviews
northbear
Post by northbear » Fri Jun 01, 2018 2:30 pm
Jon,
Drill press is nothing special but gets the job done. It is just a cheap harbor freight bench drill press. This is the model: https://www.harborfreight.com/8-in-5-sp ... 60238.html
My buildlog is here
Johnywalter
Post by Johnywalter » Fri Jun 01, 2018 4:26 pm
northbear wrote:Jon,
