Fishing rod
Mudshark
Fishing rod
Post by Mudshark » Thu Dec 12, 2013 3:27 pm
I used my shapeoko to laser cut for foam inlays, to shape the foam handles and to laser engrave the rod itself.
Rod work with shapeoko
For the inlays, I cut the EVA foam at about 1/2 watt. For shaping the foam I used a rotary attachment I had built using a stepper motor connected to one of the axis. 100 mm, 1/8" 2 flute bit, no worries on pass depth. The foam is final shaped using a drill press and sandpaper.
For the engraving, I used the rotary attachment and about 1/2 watt on the laser.
All the modeling was done with Bobcad V21 but the gcode has to be cleaned up. Snapfracturepop has a gcode parser for laser use that I have not tried.
Here is a previous picture of my rotary attachment.
Rotary attachment
Mudshark
Serial #0054, 2 Watt laser, dual X motors, double Y, ACME Z Axis, G540, Mach 3, rotating axis, needle cutter, Proxxon, 750mm x 375mm, laser cross hairs, auto zero, GT2
Ordbot #201, E3d hot end, bourdon tube feeder.
Re: Fishing rod
Post by WillAdams » Thu Dec 12, 2013 3:33 pm
Very, very cool!
Please post it to the Projects wiki page! http://www.shapeoko.com/wiki/index.php/Projects (I added a link, but it'd be great to have it in the wiki / gallery).
ThatDamnGuy
Re: Fishing rod
Post by ThatDamnGuy » Sat Dec 21, 2013 4:25 pm
That is really SLICK! ... great job!
