SSD Laser cutting
cozmicray
SSD Laser cutting
Post by cozmicray » Mon Feb 10, 2014 2:02 am
Shapeoko 2
Jtech Solid state Laser
Cozmicray's S2 with SSD Laser
Laser mount on Shapeoko 2
Micro switch wired into laser trigger port
used the fan pins to switch 12v on port
Adjustable stop to actuate laser when it goes down to zero Z
When it raises up -- micro switch opens to turn OFF laser.
Movie at:
http://www.youtube.com/watch?v=T-DSY5pNMWg
:D
MeanderBolt
Re: SSD Laser cutting
Post by MeanderBolt » Mon Feb 10, 2014 3:32 am
Great!!! This is on my short list -o- stuff I want to do with mine too.
There have been several conversations about the JTechs. Seems to be working well, and on white paper no less. Are you seeing a clean cut on all sides? I understood the 445 diodes to have an oval beam, so I was wondering if it was enough to make for problems or if it turned out clean. Also (and forgive the question), but you are wearing eye protection yes?
I look forward to seeing how far you can push it. I am curious how deep you will be able to cut, and with what. Please keep some updates coming.
I am curious if you could cut through 1/4in. black foamcore. I think it would be a sweet way to cut out pieces for foamie R/C planes.
Shapeoko 2 # 3569 - DW660
Build log
MeanderBolt
Post by MeanderBolt » Mon Feb 10, 2014 3:36 am
Sorry, one more... Will you be using any sort of air assist?
Build log
cozmicray
Post by cozmicray » Mon Feb 10, 2014 10:57 pm
This should answer question about cutting 3 mm depron
or at least bottom of a meat pack
cut is NOT exactly square (90 deg) don't know why (perhaps focus off)
yes there is a screwy square cut outside the star
Laser cut star
Movie at:
http://www.youtube.com/watch?v=yGAzMp4WPuA
Yes "S" dropped right out
wearing eye protection ?
Yes, got a high quality pair of glasses from Jtech
Not using any fan or blower yet.
:D
MeanderBolt
Post by MeanderBolt » Tue Feb 11, 2014 2:49 am
Very cool! So it cuts 3mm at a pretty good clip, so 1/4 in. is 6.35 mm, so from what you can see up close in your cut there, would you think you could slow down the feed rate and get the extra depth, or would it probably melt the foam?
Build log
