3d vs 2.5d, is it well defined?
fishtoprecords
Post by fishtoprecords » Fri Apr 11, 2014 2:30 am
I am not sure that I understand the difference between 2.5D milling and and 3D. Is there a clear difference, or is the difference as fuzzy as my understanding?
Gadgetman!
Re: 3d vs 2.5d, is it well defined?
Post by Gadgetman! » Fri Apr 11, 2014 6:57 am
The big difference is that on 'real 3D' you can undercut features or make holes that are not vertical.
PsyKo
Post by PsyKo » Fri Apr 11, 2014 8:52 am
Basically, you can do 2.5D with a 3 axis machine, and 3D with a 4 axis (or more) machine.
As mentioned by GadgetMan! 3D allows undercut.
But you can achieve 3D milling with a 3 axis machine by turning the piece being milled (with fixtures for instance). But it requires more work and precision.
Shapeoko #736
Post by twforeman » Fri Apr 11, 2014 1:09 pm
The way I define it when I am talking about CAM software (and have always heard it defined) is that 2-1/2D means making flat bottomed pockets and profiles.
3D means full surface profiling. Not undercuts.
Doing undercuts requires a 4 (or more) Axis machine, but is still called 3D.
janapriya
Post by janapriya » Fri Apr 11, 2014 3:00 pm
fishtoprecords wrote:I am not sure that I understand the difference between 2.5D milling and and 3D. Is there a clear difference, or is the difference as fuzzy as my understanding?
In general 2.5D is a sub domain of 3D. Roughly, 2.5D we have the complete control over X, Y and but half control over Z axis. In milling it is physically impossible to reach certain regions (undercuts), along Z axis, given we have material left towards the bit.
Post by cvoinescu » Fri Apr 11, 2014 3:32 pm
I'm with twforeman on this one. 2.5D is to 3D like a poster print is to a full color print. With 2.5D, you can have features at various depths, but all have flat tops and bottoms. With 3D, you can have arbitrary shapes (although only a subset can be milled on a 3-axis machine). A 2.5D object can be described by a small number of 2D drawings, each corresponding to a set Z depth. A 3D object requires a true 3D file format.
Threefer
Post by Threefer » Fri Apr 11, 2014 7:55 pm
I always thought it was as twforeman and cvoinescu describe it. You can also do shallow undercuts on a 3 axis machine using a ball end cutter with a smaller shank than the ball.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Shapeoko# 3456, Makita RT0701c. Stock size for now but have 13"x13" travel by trimming down belt clamps and lip on smooth idler. Dovetailed wooden track clamping setup. Dust shoe in works.
Post by edwardrford » Fri Apr 11, 2014 8:25 pm
janapriya
Post by janapriya » Sat Apr 12, 2014 3:15 am
Good one! :D
Threefer
Post by Threefer » Sat Apr 12, 2014 5:57 am
Awesome.
