Mr. JwC's eShapeoko [Pre-Build]
selektha
Re: Mr. JwC's eShapeoko
Post by selektha » Thu May 15, 2014 8:57 am
I am extreamly intrested in the performance of the cau cau!
Dont forget us once you have it running :)
mrjwc
Post by mrjwc » Fri May 16, 2014 4:53 pm
selektha wrote:I am extreamly intrested in the performance of the cau cau!
I actually ordered a dial gauge last night so I can measure the runout. I will do my best to keep you posted :)
Received some more packages recently; somecopper clad PCBs and the M5 spiral flute tap. It almost feels like Christmas with packages arriving almost every other day lately :D
Doh, I've still to order some end mills! Got to get that sorted this weekend, I don't wanna be stuck with a running machine and no cutting tools :p
Some 100x70mm PCBs for future projects and the M5 tap needed for assembly.
mrjwc
Re: Mr. JwC's eShapeoko [Pre-Build]
Post by mrjwc » Fri May 30, 2014 11:40 am
Have now gotten most of the parts needed for the build, except the hardware kit from A/S/L, although it should ship this week.
Ordered a runout gauge to measure the CauCau and set up a crude bench test today. See the short video below for the measurements.
Measured on an 8mm ballnose end mill.
1st measurement as close to the collet as possible: ~0.03mm
2nd measurement at ~25mm from the collet: ~0.18mm
mrjwc
Post by mrjwc » Fri May 30, 2014 1:52 pm
Moar parts!
Heatshrink tubing, cable sleeves, XLR connectors, dial gauge, USB adaptor, panel mount IEC, micro drill bits, V engraving bits, 8mm ballnose end mill
skendrot
Post by skendrot » Sun Jan 20, 2019 3:30 pm
How are these stepper motors? Would you recommend them? Where did you get the drivers?
