Single line letters
kjetilhansen
Single line letters
Post by kjetilhansen » Sat May 03, 2014 9:37 pm
Hello!
How do you make single line letters? I am using AutCad and CamBam, but in autocad when I make letters they are one line, but in CamBam it's just the outlines..
Please check the example I've attached to see what I mean :)
If you see in this picture there is single line letters that you can just color, but in CamBam my letter are like this:
When I choose the engrave tool it makes an outline of all the letters, I want it to only make a line in the middle of the letter...
Thoughts?
Re: Single line letters
Post by WillAdams » Sat May 03, 2014 11:54 pm
Options:
- CAM the letters w/ a bit setting which only allows one path
- inset the letters by just less than half the diameter and delete redudant paths
- redraw
- http://www.shapeoko.com/wiki/index.php/F-Engrave
- http://www.shapeoko.com/wiki/index.php/ ... Gcodetools
- set type using http://www.shapeoko.com/wiki/index.php/ ... rshey_Text
DanMc
Post by DanMc » Sun May 04, 2014 1:04 pm
I've been using this set http://www.mrrace.com/CamBam_Fonts/ I assume they would work in other programs too as they are TrueType.
RobCee
Post by RobCee » Sun May 04, 2014 4:31 pm
CamBam has some addon 'StickFonts' if you search the CamBam forums.
They aren't all that pretty, but they work.
Alternatively, you can use the CamBam plugin for V-Engraving and use most of the TrueType fonts, as it will use a V-Shaped bit to cut the middles of the shapes out. It works well for me.
