Non circular holes and lack of precision?
morten_denmark
Re: Non circular holes and lack of precision?
Post by morten_denmark » Wed May 14, 2014 9:04 am
Hi
My number 1 concern was non circular holes.
This is what i have done so far:
I bought a 4x40x1000 piece stainless steel bar to be sandwich in-between the two x-axis maker slide.
The modification help, but only very little. I guess that the rest of the deflection i in he V-wheels on the X-axis.
But i have tried to tighten them more, with no success.
Next step is to do some more/better work, on making my shapeoko square and plumb.
As i can see the problem occurs in the spot, where the bit make the plunge.
Post by twforeman » Wed May 14, 2014 12:54 pm
putting a flat bar in the middle will help a little, but it won't add a lot of rigidity.
I'm going to bolt a piece of angle to the inside of my makerslide, that should stiffen it up a bit.
Nigel K Tolley
Post by Nigel K Tolley » Wed May 14, 2014 2:09 pm
To gain anything there, you'll need to tighten the screws rather a lot to get the clamping force high enough to make any difference to stop them sliding and twisting.
Perhaps if you bond them with superglue?
That's semi reversible as you can kill it with a heatgun or superglue remover, but will stop the 3 pieces from sliding.
McOtis
Post by McOtis » Wed May 14, 2014 6:17 pm
I remember when milling hold down holes for my waste board, the direction of cutting made a big difference in the roundness and size. My bit was bending much more depending when I climbed or conventional cut - AKA clockwise or counter inside of MakerCAM.
Or was I imagining things due to being a complete newbie at the time? :-)
Post by WillAdams » Wed May 14, 2014 6:19 pm
On a lightweight machine which isn't too rigid, direction of cut makes a big difference --- unfortunately, there's no way to take advantage of that for a simple drill operation.
Post by twforeman » Wed May 14, 2014 8:08 pm
McOtis wrote:I remember when milling hold down holes for my waste board, the direction of cutting made a big difference in the roundness and size. My bit was bending much more depending when I climbed or conventional cut - AKA clockwise or counter inside of MakerCAM.
You were not imagining anything. Unless your machine is very rigid (the ShapeOko is not) you should always do conventional cutting.
I tried some climb cutting in maple and it was not a success.
There is some discussion here: http://www.shapeoko.com/forum/viewtopic.php?f=7&t=3375
morten_denmark
Post by morten_denmark » Thu May 15, 2014 8:35 pm
all my milling was done conventional, i did try climb... much worse!
Today i used a dial indicator, so we could get some numbers on the deflection :)
1. I think that the steel bar, between the two pieces of Makerslide did make it more rigid.
I measured the deflection on the X-axis Makerslide to be 0.1 mm
2. Measuring on the spindle, there was a bit more 0.3 mm. What is acceptable?
Here is a link to a video:
https://dl.dropboxusercontent.com/u/23750303/ur.MOV
3. Just before i went home from the workshop, i did a last try to locate the problem,
It tried to push the bit to the sides instead of back and forth (don't know why i didn't do that before).
I could see, the deflection on the sides to be worse.
I just ordered some extra V-wheel, to add on the Z-axis and see if it helps
Nigel K Tolley
Post by Nigel K Tolley » Thu May 15, 2014 9:09 pm
WillAdams wrote:On a lightweight machine which isn't too rigid, direction of cut makes a big difference --- unfortunately, there's no way to take advantage of that for a simple drill operation.
I recommend using clockwise rotation for hole drilling. ;-)
cakoceag874
Post by cakoceag874 » Sun Jun 27, 2021 5:36 pm
Jordan 11 Retro
What The Jordan 5
Adidas Yeezy Boost 350
Huaraches
Cheap Jordans Wholesale
Off White Nike
Air Force 1
Nike Wholesale
NBA Uniforms
MLB Jerseys
Air Jordan 13
Adidas
Pandora Ring
Jordan Shoes
Nike Cortez Women
Nike Shoes For Women
Nike Acg
Pandora Charms
Nike Shoes
Nike Shoes For Men
Jordan 31
Jordan 6s
Air Jordan 16
MLB Shop Canada
Jordan Retro 11
Nike Air Zoom
Jordans 21
NHL Jerseys
Jordan 35
Air Jordan 27
Cheap Jordan Shoes From China
Jordan 19
Air Jordan 12
Yeezy Static
Wholesale Jordans
Nike Running Shoes For Women
Jordans 13
NFL Shop
Wholesale Jerseys
Nike Air Force 1
Nike Roshe Men
Jordan 18
Nike Wholesale
Jordan 14
Jordan 1
Nike Lunarlon
Wholesale Adidas
Nike Huarache
Air Jordan 26
Christian Louboutin Shoes
Cheap Nikes For Men
Retro 12
Women's Nike Shoes
Jordan 2
Kids Jordans
Nike Air Force 1 Women
Nike Factory Store
Cheap Jordans
Adidas NMD
Adidas Outlet
Pandora Rings
Nike Outlet
Air Jordan 11 Low
New Jordans
Nike Store
Nike Jordan 1
New Nikes
Wholesale Nike Shoes China
Jordan Shoes
Jordan AJ 1
Jordans 24
Nike Sneakers
Nike Outlet
Nike Free
Air Force 1
Baby Jordan
Nike Running Shoes
Red Bottom Shoes Christian Louboutin
Jordans 15
Jerseys Wholesale
Air Jordan Retro
Nike Zoom
Nike Outlet
Nike Clearance
Adidas Outlet
Nike Blazers
Nike Running Shoes For Men
Air Max 2019
Wholesale Jordans From China Factory
Pandora Rings
Nike Air Max
Jordan 33
Air Force Ones
Nike
Nike Black Friday
Cheap Adidas Shoes
Nike Shoes Wholesale
Fjallraven Kanken Backpack
Jordan 33
Nike Outlet
Pandora Jewelry
Nike Jordan
Jordan 4 Retro
Air Max 95
Christian Louboutin Outlet
Nike Air Max 720
Air Jordan 23
Air Jordan 25
Nike Wholesale
Cheap Nike Shoes
Adidas China
Nike Slides
Nike SB Dunk
Nike Shoes Outlet Store Online Shopping
NHL Shop
Jordan 32
Nike Outlet Store
Jordan 29
Nike Air Force
Air Jordan 17
Pandora Bracelet
Dior Jordans
Nike Air Max 270
Lebron Shoes
Nike Air Max 270 Flyknit
Nike Outlet
Nike Shoes
Nike Foamposite
Nike Sneakers
Adidas Yeezy
Wholesale Adidas Shoes
Air Jordan Retro
Jordan 28
Pandora
Huaraches Nike
Nike Outlet
Nike Air Max 720
Air Jordan 33
Jordan 22
Pandora Official Site
Jordan 30
Jordan 20
Cheap Nike Jordan Shoes
Jordan 11 Concord
Jordan 12
Nike Uptempo
Nikes Wholesale
Pandora Charms
Pandora Jewelry
Nike Free
Nikes Shoes
Nike Outlet Store Online Shopping
Jordan 34
Cheap Wholesale Nike Shoes And Clothing
cakoceag874
Post by cakoceag874 » Tue Jun 29, 2021 11:48 pm
Ferragamo Belts
Nike Shoes
Nike Outlet
Pandora Jewelry Official Site
Pandora Store
Wholesale Jordan Shoes
Nike Shoes
Nike Factory Store
Nike Sneakers
Pandora Charms Outlet
Jordan 1's
Adidas Running Shoes
Air Jordan 1 Mid
Pandora Bracelets Clearance
Pandora Charms
Adidas Official Site
Jordan 1 Retro
Cheap Moncler Coats
Pandora Jewelry Outlet
Adidas Canada Online Shopping
Triple S Balenciaga
Pandora Charms Bracelets
Pandora Jewellery
Pandora Charms
Pandora Outlet
Wholesale Jordan Shoes From China
Balenciaga
Jordan 1 High
Pandora Rings Official Site
Yeezy
Moncler Sale
Nike Shoes Women
Moncler Outlet
Nike Outlet
Pandora
Nike Canada Online
Nike Sneakers For Women
Pandora Bracelets
Moncler Coat Men
Pandora Jewelry
Puma Shoes
Adidas NMD
Pandora Jewelry Charms
Pandora Charms
Adidas Shoes Men
Cheap Nike Shoes
Pandora Outlet
Pandora Jewelry
Nike Shoes
Salvatore Ferragamo
Nike Canada Online Shopping
Pandora Jewelry
Adidas Sneakers Men
Asics Gel-Kayano
Pandora Charms
Pandora Jewelry
Adidas New Shoes
Asics Shoes
Jordan Retro 1 High OG
Cheap Adidas
Goyard Handbag
Nike Canada
Jordans 1
Nike Outlet Online
Air Jordan 1 Retro
Adidas Trainers
Asics Outlet Online
Pandora Charms
Air Jordan 1 Low
Pandora Outlet
Jewelry Pandora
Air Jordan 1 Dior
Pandora Outlet
Nike Running Shoes Sale
Nike Shoes
Jordan Ones
Moncler Jackets Outlet
Moncler
Adidas Yeezy
Pandora
Pandora
Nike Air Jordan 1
Nike Shoes Women
Ferragamo Belt
Pandora Outlet
Pandora Bracelet
Adidas Yeezy
Nike
Yeezy Boost 350 V2
Pandora
Pandora Outlet
Cheap Jordan Shoes For Women
Moncler Jacket
Adidas Canada
Pandora Outlet
Nike Men Shoes
Nike Outlet
Nike Store
Moncler Coats
Pandora Charms
Balenciaga Sneakers
Pandora
Pandora Jewelry
Pandora Rings
Asics Shoes Outlet
Nike Canada Outlet
Pandora Jewelry
Jordan 1 Lows
Pandora Jewelry
Adidas Outlet
Asics Sneakers For Women
Womens Basketball Shoes
Ferragamo Belt
Asics Running Shoes
Balenciaga Sneakers
Nike UK
Wholesale Jordans
Balenciaga
Goyard Bags
Nike
Adidas
Adidas Shoes
Balenciaga Shoes
Pandora Outlet
Men Nike Sneakers
Balenciaga Shoes
Pandora Charms
Adidas Women's Shoes
Pandora
Adidas Clearance Sale
Ferragamo Shoes Women
Jordan 1
Asics Shoes
Air Max 720
Pandora
Nike Mens Shoes
