USB Ground Loop
TheMonkeyStink
USB Ground Loop
Post by TheMonkeyStink » Wed Jun 04, 2014 5:30 am
Hey All,
In putting together my new SO2 I discovered that there appears to be a pretty big potential difference between the ground plane of the Arduino and my PC. It's so bad that if I plug in the USB cable it triggers a protection circuit in the 24v power supply. Has anybody else seen this? Or did I screw something up?
BTW, I found and ordered a USB ground loop isolator (I didn't even know such a thing existed), I'll report back if that really does solve the problem.
________________________________________
Shapeoko 2 #5177: DW660 with nema 23. Acme Z axis (I believe these come from the same company that Wile E. Coyote gets his stuff)
# of failed cuts (a.k.a. Shapeoko Ohnos): 7
# of successful cuts: 12
TheMonkeyStink
Re: USB Ground Loop
Post by TheMonkeyStink » Wed Jun 04, 2014 9:05 pm
Just as a quick update, I got my hands on one of these:
http://www.amazon.com/gp/product/B00F4S ... UTF8&psc=1
And now I can plug in both the 24v power supply and the USB cable without issue. I haven't checked functionality yet, but I think I'm on the right track.
As a note, this specific device is supposed to have a poor quality track record...we'll see if I can talk to the Arduino.
TheMonkeyStink
Re: USB Ground Loop
Post by TheMonkeyStink » Fri Jun 06, 2014 2:45 pm
Okay, it appears that commands are passing just fine through the USB isolator.
With that being said, I've been browsing the forums and I don't think this is an isolated issue. There are reports of device failures that could very well be attributed to large potential differences between the ground plane of the Arduino and the PC. My question is, where would be a good place to post a warning? Is this post adequate?
