Fusion 360 grbl Post Processing Script
TheMonkeyStink
Post by TheMonkeyStink » Wed Jun 18, 2014 3:58 pm
Hello Folks,
For those of you using Fusion 360 I have a request, could you try out the enclosed files to see if they work as post scripts for grbl/gShield? I've tried the gShield.cps and it appeared to work, but my design was fairly simple. The only apparent problem I had was that UGS seemed to have problems shutting down after processing the output file, but that could be due to the size of the file. Any input would be appreciated.
gShield.cps.txt
A file that *I think* was tailored for grbl running on an Arduino
(12.99 KiB) Downloaded 69 times
generic_grbl.cps.txt
A generic grml post produced by Autodesk
(16.75 KiB) Downloaded 63 times
________________________________________
Shapeoko 2 #5177: DW660 with nema 23. Acme Z axis (I believe these come from the same company that Wile E. Coyote gets his stuff)
# of failed cuts (a.k.a. Shapeoko Ohnos): 7
# of successful cuts: 12
arjan
Re: Fusion 360 grbl Post Processing Script
Post by arjan » Thu Jun 19, 2014 4:56 am
Im using Inventor HSM with the tiny G post and it is ok(same posts same milling kernel) . Ugs is not the most stable solution but it works.
Verstuurd vanaf mijn GT-N7100 met Tapatalk
