Edge lit Plexiglass Night Light
dataway
Post by dataway » Fri Oct 10, 2014 8:23 pm
This is my first go at creating a Edge Lit Plexiglass sign for a friends daughter celebrating her 4th birthday.
I milled the plexi using a 60deg v-bit for the graphic of hello kitty I then used a diamond tipped spring loaded engraving bit to etch her name into the heart. I then milled the base as a 3D milling job first cutting the top slot then doing a profile milling operation to mill out the base half way through the wood as I did not have a bit to mill all the way through. I then flipped the board and milled out the bottom to fit the electronic and widened the slot for the plexi at the bottom to hole the LED lights. I then did a second profile operation to cut the rest of the way through the wood to finish the base. I then milled a piece of aluminum to act as the bottom cover put it all together and this is the final result....
Base Side View
base_Side
Base Top View
base_top
Sign complete
sign_complete
dataway
Re: Edge lit Plexiglass night light
Post by dataway » Fri Oct 10, 2014 8:24 pm
......Here is the night light lit up
Night light turned on
lit up
Note in this image the small ring on top where the plexi enters was not there, I added the upper ring to the base to further hide the led lights below.
dave_the_nerd
Re: Edge lit Plexiglass Night Light
Post by dave_the_nerd » Sat Oct 11, 2014 12:14 am
That is cool; I hope she likes it!
philc
Post by philc » Sat Oct 11, 2014 1:14 am
It looks awesome. Great job!
Shapeoko 2 - CNC Shield & TinyG - 400w spindle - (Sketchup -> CamBam -> GCode Teleporter)
My Software: GCode Teleporter - GCode Truncater
http://www.thingiverse.com/philc
ALuomala
Post by ALuomala » Sat Oct 11, 2014 2:58 am
Where did you get the spring loaded engraving bit, or is it something you custom made? I want to start working on similar projects, so I want to be ahead of the curve when I start.
Thanks,
Allan
ShapeOko2, serial ??
DW660 spindle;
dataway
Post by dataway » Sat Oct 11, 2014 3:57 pm
Thanks for the positive comments ...
@Allan - I got the bit off of ebay you can see it here, make sure you get a spring loaded one....
http://www.ebay.com/itm/151402216873?_t ... EBIDX%3AIT
izumi5188
Post by izumi5188 » Wed Feb 11, 2015 10:30 pm
I see this is an older post. But you've had luck. I'm trying to mill plexiglass as well. What are your feeds and speeds, if you don't mind sharing?
-IzumI-
Shapeoko 2 : With Works Kit and 1000mm Expansion
Upgrade with X-Carve, Acme Screw kit, and X-Controller
