I really liked what PsyKo had done to create belt tensioners here: http://www.shapeoko.com/forum/viewtopic ... 608#p12474
The problem was that I didn't have the metal plates to create clamps or the extra length in my belts. So after giving it some thought I came up with this.
I used the existing epoxy/fiberglass belt clips that came with the kit, a nut and bolt (you could use the same nut and t-bolt meant for the clip), and a small nail or brad to anchor the belt. It might be more rigid with metal instead of the belt clip, but there is no apparent flexing the way it is.
I've been able to get my belts tighter and, with four of these, an extra 2 inches of y-travel.
Quick and easy Y-axis tensioners
- Attachments
- Simple Y-axis tensioner
- y-axis-tensioner.jpg (78.54 KiB) Viewed 1659 times
ShapeOko 2 #6502 w/ NEMA 23 (140oz) motors (X and Y), Acme Screw Z-axis, Arduino/grblShield/grbl v0.9g
Spindles: Dremel 395; 400W BLDC
Re: Quick and easy Y-axis tensioners
Very nice!
Also similar to what Little Hands did here: http://www.shapeoko.com/forum/viewtopic ... 174#p26328
That was already on the wiki, so added your post and gave the two their own sub-head:
http://www.shapeoko.com/wiki/index.php/ ... tive_usage
That's a wonderful reuse of existing components in a better way!
Also, PsyKo's reinterpretation of the eShapeoko clamping and tensioning mechanism is beautiful, in all that brushed aluminium.
Thanks, indeed it was taken from the eShapeoko designcvoinescu wrote:Also, PsyKo's reinterpretation of the eShapeoko clamping and tensioning mechanism is beautiful, in all that brushed aluminium.
Nice work aeleus.
Shapeoko #736
