GrblGru
Post by GrblGru » Fri Jun 19, 2020 6:36 pm
The 1st digit of the version number is the main version. It is only changed if something very important has changed.
The 2nd digit is the current released version.
The 3rd digit is only available for beta versions (not yet released trial versions)
V3.48 is larger (i.e. newer) than V3.45.(13).
This means that V3.48 should work for you. :)
GrblGru
Post by GrblGru » Mon Jul 13, 2020 11:22 am
Release notes V3.49
once again I would like to announce a new version of my program GrblGru.
The attached video "From Carving to Inlay (part 2)" this time concerns the creation of raised text.
The reworked function "Pocket Contour parallel" for machining pockets with islands thus provides the basis
for the production of inlays, which however can only be presented in the next version.
Nevertheless I hope that there is already something interesting for some of you.
Have fun with GrblGru
dgamble1
Post by dgamble1 » Wed Jul 22, 2020 7:40 am
Hi GG
I love the V carve videos and have been trying to implement them on my router lathe. I downloaded some text from F-engrave and managed to project it onto the 4th axis OK. Unfortunately "Vcarve" mode does not support transformation "Projection".
If I try cutting the projected text from F-engrave the tool follows the text outline, resulting in a poor result.
Is it possible to project the V carve text or alternatively get the tool to follow the centre line of the TTF font?
Regards
GrblGru
Post by GrblGru » Thu Jul 23, 2020 11:15 am
@dgamble1
Projection should now work in the new beta version V3.49.4.
But you have to load a suitable STL part before, so that the font or whatever can be projected on it. It should also work on turned parts that are not cylindrical.
Image 1.jpg (123.55 KiB) Viewed 1773 times
Image 2.jpg (89.12 KiB) Viewed 1773 times
GrblGru
Post by GrblGru » Tue Sep 08, 2020 9:14 am
Beta notes V3.49.9
On my website is a new beta version V3.49.9. It contains the first attempt to make measuring on the lathe available again.
I have made a short video about it. It shows how to measure an STL object virtually. The calculated GCode can also be sent to the controller.
Unfortunately my probe is not working at the moment. Therefore I could not make any tests in practice.
GrblGru
Post by GrblGru » Thu Sep 24, 2020 6:45 pm
GrblGru @Linux ?
I have been asked many times if GrblGru is also available for Linux. Until now I always had to deny this.
But now a clever user has found a way to run GrblGru on "Wine" under Linux.
According to him it is still possible to improve the process.
Since I have no experience with Linux, I can only pass on the instruction on my website at the moment. (See https://www.grblgru.com/)
I would be very happy if the Linux gurus of this forum would take a look at it.
Necessary information and also changes for further improvements I will gladly provide.
GrblGru
Post by GrblGru » Thu Oct 29, 2020 8:35 pm
Just a short information. On my website there is a beta version V3.49.14 with the new operation mode "Tangential Blade".
GrblGru
Post by GrblGru » Thu Dec 17, 2020 5:46 pm
Release notes V3.50
I finally managed to finish the 3rd video on how to make inlays.
At the same time I also uploaded a new release version V3.50 to my WebSite.
The video has become longer than usual.
This is because I also tried to tell a little bit about the background and possible problems.
In most internet examples about inlays, only very simple geometries are shown.
There everything always works at the push of a button. In 'my' reality, however, these examples never occur.
I hope by providing the necessary function and the corresponding explanations to put you in a position
to determine the necessary steps by yourselves and thus to tackle more demanding projects.
Of course this is a bit more work for the user, but it is also more fun. :)
Suggestions and also criticism are as always welcome.
GrblGru
Post by GrblGru » Tue Dec 29, 2020 8:07 pm
Just a short info. There is a new beta version v3.50.3 on my website.
In lathe mode, when loading DXF files, the job template whose name starts with a '#' is now automatically started. I hope this makes turning geometry from DXF files even easier.
I am especially happy about a new french translation from user "LETARTARE". On name of all french speaking users a big thank you.
Alexmoon
Post by Alexmoon » Fri Jan 22, 2021 7:35 pm
Hello friends!
I am experimenting with alternative control units for my machine.
And I'm surprised that under the control of the Grbl controller, the machine runs smoother and quieter than under the control of Mach3.
The settings are the same for all (drivers, current, microsteps, approximation, etc.).
Question to all gurus on Grbl:
What in the Grbl algorithms allows you to control motion so effectively? :)
In a short video, I demonstrated the difference in machine noise with different controllers.
https://youtu.be/QUlNYQ7euBk
