A little journey in 4 axis milling.
PsyKo
Post by PsyKo » Sun Feb 01, 2015 9:11 am
Hello,
I've recently had time to plya with my 4th axis and I'm pretty happy with the results.
First, the model I chose is this one : http://www.thingiverse.com/thing:530088. Decided to only mill the torso.
For GCode generation, I used a trial version of deskproto 6. Didn't really had time to get used to it, but I managed to achieve this project.
Here is the result, viewed in my TinyG control software :
Roughing passes on a 40mm diameter Delrin cylinder
Finishing passes using 3mm ball nose mill.
I also made a finishing pass using 1.5mm ball nose mill, but the GCode is basically the same as the finishing pass above.
And here is the result :
Final result next to a AA battery
Shapeoko #736
PsyKo
Re: A little journey in 4 axis milling.
Post by PsyKo » Sun Feb 01, 2015 9:12 am
Shapeoko #736
Brian Stone
Post by Brian Stone » Sun Feb 01, 2015 9:34 am
- "Is this some kind of bust?"
- "Yes, it's very impressive, but we need to ask you a few questions."
Great results for a first try. Great results for a 10th try, really. What is the largest diameter you can mill with it? And can you post some photos of the machine?
Shapeoko 2 #7353
lioramsalem
Post by lioramsalem » Sun Feb 01, 2015 9:54 am
+1
Photos, information, etc..
Looks very impressive.
Regards,
LA
ShapeOko 2 #5840 w/ NEMA23, ACME Z axe belt upgrade, limit switches, spindle speed control, 400w brushless spindle, 9mm belts, aluminum bed, eShapeoko X carriage and belts system
Build log: http://www.shapeoko.com/forum/viewtopic.php?f=5&t=3650
cmcta82
Post by cmcta82 » Sun Feb 01, 2015 11:44 am
Can you share information about your 4th axis, its very impressive!
PsyKo
Post by PsyKo » Sun Feb 01, 2015 12:04 pm
Brian Stone wrote:- "Is this some kind of bust?"
It's my first result with a completet 4axis CAM software. Before I did them using Cambam and some trickery.
My 4axis v1 presentation is here (The v2 is only a replacement of the 2 extrusion rails with a solid aluminium plate)
http://www.shapeoko.com/forum/viewtopic.php?f=30&t=2819
And my machine is here :
http://www.shapeoko.com/forum/viewtopic.php?f=30&t=1608
I can't get to my workshop now, so that will be the only pictures I can show you for now.
Brian Stone wrote: What is the largest diameter you can mill with it? And can you post some photos of the machine?
I do have a 80mm chuck. But the diameter is limited by the maximal Z of the machine. And to be honest I have no idea. I already rounded some 80mm support for the chuck. I think I can go bigger depending on the 4th axis setup, which is not definitive for now.
Shapeoko #736
DanMc
Post by DanMc » Sun Feb 01, 2015 4:03 pm
Awesome work!
I had been shying away from building a belt-driven 4th axis, worried about backlash, but I may have to reconsider.
PsyKo
Post by PsyKo » Sun Feb 01, 2015 6:21 pm
I do have a little backlash, but only because the belt is not properly tensionned.
I have to figure out a belt tensionner that fits my design.
Beside I'm working on a worm gear driven 4th axis for now. It should be smaller.
Shapeoko #736
MeanderBolt
Post by MeanderBolt » Sun Feb 01, 2015 7:52 pm
Holy crap. That's really cool. Man, if I were into chicks with no arms, or legs...
How long did this take?
Shapeoko 2 # 3569 - DW660
Build log
PsyKo
Post by PsyKo » Mon Feb 02, 2015 1:39 pm
MeanderBolt wrote:How long did this take?
Don't remember exactly, but it was ~4h of pure milling, including roughing, 1st and 2nd finishing passes.
Shapeoko #736
