Simple & cheap clamping of workpieces
Postby GrblGru » Thu Sep 24, 2015 6:09 pm
In this forum I've seen a lot of solution for clamping the workpiece on the wasteboard. But I'm missing a very simple and also cheap variant, that I've used for my little DIY milling machine. I've drilled 6mm holes in my board and have plugged plastic dowels in each hole. This allows the using of simple wood screws.
Free download from my dropbox: bit.ly/2xF1KJ8_GrblGru_Release
GrblGru
Re: Simple & cheap clamping of workpieces
Postby WillAdams » Thu Sep 24, 2015 6:48 pm
Ingenious!
May have to try this instead of T-nuts in my next wasteboard. Certainly far more affordable.
Postby TomO » Thu Sep 24, 2015 8:51 pm
Great idea & it's not much of an issue if you run a bit into one.
TomO
Postby WillAdams » Thu Sep 24, 2015 10:07 pm
Could one get a nylon screw into one of these (and back out)?
That’s one of the nice things about the T-nuts I’ve been using is that I can put a nylon machine screw into them and not worry about hitting it (actually was cutting them off for the paths of the Studley calipers).
Postby GrblGru » Fri Sep 25, 2015 10:54 am
Thanks. I don't know, because I've never try it.
But at first I've tried normal metal screws with less pitch than the wood screws. To fix the workpiece you need a lot of revolutions. Because I'm lazy I prefer the wood screws. :)
GrblGru
Postby fasteddy » Fri Sep 25, 2015 2:19 pm
Interesting solution. But how often can you insert/remove screws before the insert is stripped? They're cheap to replace, anyway.
fasteddy
Postby twforeman » Fri Sep 25, 2015 2:40 pm
WillAdams wrote:Could one get a nylon screw into one of these (and back out)?
Nylon screws is a great idea! I've been using brass screws in my fixtures because I figure hitting one of those won't cause any issues.
On the other hand, I did run an 1/8" end mill through the mild steel plate on my vise at rapid with no apparent damage... viewtopic.php?f=7&t=4445
Prusa i3 3D Printer
Postby WillAdams » Fri Sep 25, 2015 2:50 pm
Thanks. They're also less expensive than brass.
I had to plan the paths so that I'd be pretty much cutting off most of one screw on my locking register calipers:
I also used aluminum screws other places where the risk was lower --- probably those would be fine for the plastic insets
Postby JimInAshland » Mon Sep 17, 2018 3:46 am
Anyone hear of using plastic nails with a nail gun?
I have used regular brads with a nail gun and it doesn't rip up the waste board like a screw does.
It is quick in and out.
Obviously it works for soft wood but not when I am milling plexiglass :)
Shapeoko XL newbee
JimInAshland
Postby WillAdams » Mon Sep 17, 2018 2:29 pm
Yes, folks have used the raptor nails, see:
https://www.shapeoko.com/wiki/index.php ... #Fasteners
Return to Design Ideas
Who is online
cron
