vertical storage idea
Postby cfinklea » Sun Nov 08, 2015 2:21 pm
Screen Shot 2015-11-08 at 11.56.13 AM.png (214.35 KiB) Viewed 5422 times
cfinklea
Re: vertical storage idea
Postby Gadgetman! » Sun Nov 08, 2015 2:44 pm
I would probably have added legs to the corners, and fastened them with hinges or a bolt of some sort.
As long as the platform the SO is mounted on is solid, it should work.
Gadgetman!
Postby AnonymousPerson » Sun Nov 08, 2015 4:43 pm
Or add a motor and turn it into a 4th axis. :D
AnonymousPerson
Postby cvoinescu » Mon Nov 09, 2015 3:15 am
That's a wonderful idea!
I have a torsion box for a 750 mm by 1000 mm machine, and I wanted to add legs to make it a cart. However, the machine would be too wide to fit through standard doors without taking the legs off. Hinging it in the middle like that would allow the cart to be narrower. I can't reuse the legs I've already made, so I may not adopt this idea after all, but it's something to consider.
Postby JayTeague » Fri Nov 13, 2015 3:09 pm
Interestingly enough I am actually in the middle of upgrading my (constantly enhanced and tweaked) SO2 with just that type of a table.
I have designed mine such that it is a torsion box table, 2 - sided., such that I can rotate it 180 degrees if I should need large work bench space instead of the CNC at times - and also to store vertical so that I can re-capture space when not in use.
I will try to remember to grab some pics and post them.
JayTeague
Postby cfinklea » Sun May 15, 2016 10:37 pm
Finally had the time to make the upgrades
cfinklea
Postby cfinklea » Sun May 15, 2016 10:38 pm
More pics
cfinklea
Postby xfredericox » Mon May 16, 2016 8:32 am
grrrreat!
http://www.manmademayhem.com
xfredericox
Postby btonns » Wed Nov 28, 2018 12:57 pm
JayTeague wrote:Interestingly enough I am actually in the middle of upgrading my (constantly enhanced and tweaked) SO2 with just that type of a table.
I know this is an old thread, but do you happen to have pictures of your torsion box cart?
btonns
Postby JohnManly » Mon Jan 21, 2019 9:29 pm
Now that you've had a couple of years to use it with the cart, have you had any issues? Specifically, I'm curious as to whether storing the unit on its side requires re-calibration when you go to use it again.
JohnManly
Return to Design Ideas
Who is online
cron
