Vacuum Table!
Vacuum Table!
Post by edwardrford » Sat Jan 16, 2016 1:01 am
Hi All,
Went out to the C3D shop in California this week to do some R&D and hang out with the rest of the crew. Plus, it's very cold in IL right now, so if nothing else - seeing the sun was a nice change of pace!
Anyway - we had some fun yesterday using Carbide Create to design a vacuum table we've been talking about for a long time now. The entire thing can be cut with a 1/4" square endmill.
Between designing, cutting, and gluing the project took a couple of hours. The results were good.
After using the table for a couple of jobs I have some ideas to make it better
- putting locating holes on the top and bottom to better line them up when glueing
- putting inserts into the bottom so the top is easily replaceable
- putting holes in the side that match up with the aluminum table holes
Using a regular shopvac produced enough pull to hold down a sheet of acrylic (which I accidentally cut all the way through as you can see in the pictures...). Later in the day I masked off a good part of the table with masking tape and engraved on a piece of renshape, which also worked very well.
If you're interested in making one of your own, here are the c2d files (one for top, one for bottom)
vacuum_table.zip
(12.91 KiB) Downloaded 416 times
Here is the flanged adapter I used: http://www.amazon.com/gp/product/B00AX5 ... detailpage
If you do make one of your own, send us a picture (sales@carbide3d) with the subject of 'vacuum table'. if you're one of the first 10 pictures we get, we'll send you a free 1/4" cutter for being awesome.
AnonymousPerson
Re: Vacuum Table!
Post by AnonymousPerson » Sat Jan 16, 2016 3:11 am
That looks interesting. I've recently been mucking around with other vacuum stuff, but haven't tried making a vacuum table yet. Might give that a shot.
With the c2d files... is that the file extension used by Carbide Create? Doing Googling for c2d, the only results are for a disk image program which makes no sense in this context. :wink:
Shapeoko 3 #516
Brian Stone
Re: Vacuum Table!
Post by Brian Stone » Sat Jan 16, 2016 7:18 am
This is really cool, Edward. Thanks for sharing. I need a bigger machine before it makes sense for me to build a vacuum table though... I'm crossing my fingers for a 2'x4' S3 option!
Shapeoko 2 #7353
TonyB
Re: Vacuum Table!
Post by TonyB » Tue Jan 19, 2016 2:25 am
Awesome! I'd love to see it in action, any videos?
I was also kind of curious, if your material doesn't cover all the holes, is it still effective?
410whp/411ftlbs
Build Thread
AnonymousPerson
Re: Vacuum Table!
Post by AnonymousPerson » Tue Jan 19, 2016 9:50 am
Vacuum cleaners need to draw in air for cooling don't they? If that's the case, then a completely air tight solution might blow it up? :D
If not, then something like Neoprene rubber might work for covering up the holes. :)
http://www.amazon.co.uk/gp/product/B00FF5RSB4
Shapeoko 3 #516
atrueresistance
Re: Vacuum Table!
Post by atrueresistance » Sun Jan 24, 2016 7:39 pm
I downloaded the zip, looks like just the bottom file was included.
Shapeoko 1 #unknown
Shapeoko 3 #572
Checkout my Etsy Store
atrueresistance
Re: Vacuum Table!
Post by atrueresistance » Sun Jan 24, 2016 9:27 pm
Bottom done!
Shapeoko 1 #unknown
Shapeoko 3 #572
atrueresistance
Re: Vacuum Table!
Post by atrueresistance » Sun Jan 24, 2016 10:14 pm
Here is the top file I come up with based on the bottom
vacuum_table_top.zip
(4.14 KiB) Downloaded 193 times
Shapeoko 1 #unknown
Shapeoko 3 #572
AnonymousPerson
Re: Vacuum Table!
Post by AnonymousPerson » Sun Jan 24, 2016 10:42 pm
Your base looks good. :)
One of these days I'll try out Carbide Create. Today isn't that day though. ;)
Shapeoko 3 #516
atrueresistance
Re: Vacuum Table!
Post by atrueresistance » Mon Jan 25, 2016 12:38 am
Link to photo album https://goo.gl/photos/aMwuevWKJGHRobc69
I'm going to try and glue it up with a piece of paper in between. My thought is you should be able to easily pry off the top when putting a new sheet on. I cut a small dado to fit onto the front plate of the SO3. This has the benefit of always placing the vacuum table on the machine square, and helps with torsion. I use the 3m double sided tape to attach everything to the spoilboard :-) Not all of us have a fancy aluminum board :-P When are those going on sale by the way?
Shapeoko 1 #unknown
Shapeoko 3 #572
