Where to get this shim?
DRobs86
Post by DRobs86 » Sat Apr 16, 2016 12:56 pm
I need a washer that is about 5 ID (or a little oversized for clearance of a 5mm bolt) with an OD of about 8mm or less. This is not a standard size. I didn't see anything at Fastenal. Does anyone have any advice on where to get it?
GoSpeedRacer
Re: Where to get this shim?
Post by GoSpeedRacer » Sat Apr 16, 2016 2:28 pm
Any specific type of washer? On RC cars we use 5mm fiber washers a lot as bearing spacers, Part number is 1985
5mm X 8mm X 0.5mm ptfe coated teflon washers
eBay or local hobby shop are easiest sources
DRobs86
Post by DRobs86 » Sat Apr 16, 2016 6:54 pm
Outstanding. Thanks for the help on it. As I think about it more, I am probably going to be safer with a 5 mm ID and 7 mm OD. I put my micrometer back on it and if it's a little off centered when I tighten things up then I'll be on the outer race. I did see some shims in that ID and OD, but they were 0.1mm - 0.3mm.
Thanks again.
Post by cvoinescu » Mon Apr 18, 2016 9:20 pm
Is this what you're looking for?
DRobs86
Post by DRobs86 » Mon Apr 18, 2016 9:51 pm
Thanks for the pointer CV. I ended up ordering some of the traxxas washers that SpeedRacer referenced. If those prove to be too close of a fit I may have to grab some from you.
Post by twforeman » Tue Apr 26, 2016 2:47 pm
McMaster-Carr has a lot of shim options...
http://www.mcmaster.com/#standard-shims/=125f5jz
