CNC shield V4 Arduino Nano not working
alhaddar
Post by alhaddar » Sun Jun 12, 2016 10:50 pm
On my CNC shield V4, the STEP and DIR was not corresponding between the pin layout from the Android Nano and the step driver board. After switching both pin the bor start to work
Now how are changed Pins by programming
I ask you my friends on the way, because I do not have any idea how to change
https://www.youtube.com/watch?v=ZX3t-2s3XUo
AnnyMore
Re: CNC shield V4 Arduino Nano not working
Post by AnnyMore » Wed Mar 20, 2019 6:18 pm
Hi...Are you sure you have the A4988 boards correctly oriented? In other words, if they were put in place flipped around, would the pins vs function match?
Given that these boards are custom things from China, they very well could be made wrong, or maybe the CNC software they are using with the board uses a different pin spec?
pcb assembly in usa
