Milling bevels and through-holes in a large heatsink
Brian Stone
Post by Brian Stone » Tue Aug 16, 2016 10:23 pm
Thought I'd post this, since it's sort of the first big chunk of aluminum I've milled on my S2. I've done some smaller aluminum projects in 6061 bar stock, but those were just simple experiments that didn't really teach me how to mill aluminum.
A friend of mine had a large heatsink (about 8" square) that required modification and mounting holes drilled. I offered to do the job on my S2 for the extremely generous price of one beer. Here's the result.
RPM: 20,000
MILL: 1/4" 2-Flute Square
45 degree bevels --
Feed: 1200mm/min
DOC: 0.25mm
Ratchet clearance helical bores --
Feed: 800mm/min
DOC: 0.25mm per helix revolution
Through hole helical bores --
Feed: 300mm/min
DOC: 0.1mm per helix revolution
The through holes were milled in 2mm depth increments though 7.5mm total thickness. After each increment the end mill was raised to clear chips.
Incidentally, the beer was excellent and more than adequate compensation.
Shapeoko 2 #7353
zerblatt007
Re: Milling bevels and through-holes in a large heatsink
Post by zerblatt007 » Wed Aug 17, 2016 8:00 am
Nice!
Was it difficult to hold it down securly?
Brian Stone
Post by Brian Stone » Wed Aug 17, 2016 4:30 pm
Not difficult at all. I used just a few strips of double-sided foam tape.
Shapeoko 2 #7353
