Shapeoko 2 + Laser - Cant get working
Gooliez
Post by Gooliez » Mon Oct 03, 2016 12:41 am
Hi Guys, had my shapeoko 2 for a while and finally pulled out the laser i've had that i bought off ebay year and a half ago...
The laser i got was the one recommended on the WIKI
http://www.shapeoko.com/wiki/index.php/Laser_Cutter
I cant seem to get it working.
Power is working, the Fan is rotating
Laser is on when the TTL / Ground pin isnt attached to the Head unit ( see pic)
When i connect the TTL, the laser turns off, but fan still rotates
when i run the "Focus point" test in step 2 of the wiki, the system moves, but the laser doesnt "BURN" the test piece ( no light )
I've got the + TTL connected to Pin 12 of the Ardruino, - TTL connected to ground ( i've swapped them around to make sure they werent the wrong way like in the wiki )
i've got a 12v power Supply running to it. so there's enough power
do i need to do anything GRBL wise or anything to get the laser working, or have i connected something wrong somewhere ?
Also i know it's Dodgy mounting etc, For the time being i'm just trying to get the thing working, then i can work on the cosmetic stuff.. lol
cozmicray
Re: Shapeoko 2 + Laser - Cant get working
Post by cozmicray » Mon Oct 03, 2016 4:41 pm
What grbl version are you using?
See
https://jtechphotonics.com/?page_id=1100
A grbl version that supports laser should be used,
there is a command to put grbl in "laser mode"
Gooliez
Post by Gooliez » Tue Oct 04, 2016 10:17 pm
pretty sure it's 0.8, however to be 100% sure i also tested on both pins 11 & 12, no difference
thanks for the reply, thought you guys had abandoned me
lowrizzle
Post by lowrizzle » Sun Oct 09, 2016 6:40 am
Are you using M3/M5 or M3 S10000/M5 to activate/deactivate the laser? M3 PWM settings did not work for me since I'm running mainline GRBL. My diode would not turn on unless I'm above, say, M3 S9000.
Gooliez
Post by Gooliez » Sun Oct 23, 2016 11:31 pm
Sorry about late reply....
i'm just running the test run at the moment.
g21 (nn)
g0 x0 y0 z0 (zero point)
g3 (turn on laser)
g1 x10 (burn a test line)
g5 (turn off laser)
g0 x0 y2 z2 (go to the beginning of the next line)
g3
g1 x10 (burn another test line)
g5
(and repeat)
