First time trying to generate Gcode in Fusion360 and when I start the job the machine jogs straight up until the z limit switch is hit. Before that I tried setting all the heights for the pocket to 0 and it would still start the pocket operation above (approx 0.2") where I zeroed on the stock using a touch probe. I don't think it's my machine because code I've generated from other programs works fine.
Here is a link to the 360 file: http://a360.co/2DVLBOW
Fusion 360 Gcode problems
Re: Fusion 360 Gcode problems
Usually this is caused by a disconnect in origin in the file (bottom) and where / how one sets zero relative to the stock (on the top).
Fusion 360 needs a post processor file loaded to work with the Shapeoko (or any GRBL controlled machine).
One of the earlier ones I used had a mistake in it. It sent the z acis to 15 in the first line of g code. The rest of the code worked just fine. You just had to edit the .NC file and make first z move something that was within the limits of your z axis. Later versions had a z height setting that could be set in the post processor options.
CBB
CBB
It was actually the origin being set to the bottom of the piece instead of the top like Will said. Thanks Will!
