A little help with drawing in CC
stioc
Post by stioc » Sat Feb 03, 2018 6:46 pm
I found this DXF of a fidget spinner which Chrome opens just fine: https://drive.google.com/file/d/0B92OWu ... R1TG8/view but CC errors out on it.
Anyway so I imported a BMP image as the background so I could trace it. However, now (and this is what I want to learn) I'm kinda stuck with the Boolean operation after the first one I tried which semi worked (snapping a rectangle across the three circles. The purple lines is what I want but can't figure out how to draw those and get rid of the other lines. I guess ask another way how would you do this trace? Thanks for any pointers.
Re: A little help with drawing in CC
Post by WillAdams » Sat Feb 03, 2018 7:52 pm
I was able to get the file to open as an SVG by:
- opening in LibreCAD
- exporting as a MakerCAM SVG
- opening the SVG in Inkscape
- re-saving after making it into a composite path.
See: https://www.shapeoko.com/wiki/index.php/File:Fidget.svg (you may need to verify the size)
To draw the angles you want, you could use polylines (closed), or rotate rectangles.
stioc
Post by stioc » Sat Feb 03, 2018 8:08 pm
Thanks Will! I'm able to open your SVG file perfectly! See the attached error when I was trying to import the dxf.
I tried the polys and finally got this one to work but some just didn't do anything at all. I figured the lines have to clearly intersect so I made sure of that but it was a hit or a miss. I'll figure it out with more practice I'm sure.
