Z-Axis losing steps and sleepwalking stop command
kboruff
Post by kboruff » Wed Feb 14, 2018 2:11 am
Hey all! I just got my machine and have setup and squared everything, but before I do any projects I wanted to make sure I have a workable wasteboard.
I have a piece of 1/2" MDF and I'm planning to drill and face mill that to finish getting everything ready.
I've been having some trouble with my new machine losing steps in Z as I am going through a drill command or if I start trying to contour the MDF edges to square angles. I made a short series of videos to show the trouble I'm running into and some of the stuff I've tried. I'm on the latest firmware because before I installed it my computer couldn't communicate with the Shapeoko 3. I'm on a Microsoft Surface Book and I'm using Fusion 360 to make the program and the stock Carbide Motion to send it.
Losing Z depth issue
https://youtu.be/xy-q4P4i7AM
https://youtu.be/8vogNOFipmQ
https://youtu.be/YAy7bFAu-yA
Additionally, I've found when I hit stop, the head will loop whatever the last motion command it received was.
Motion loop error when hitting Stop in the Run menu.
https://youtu.be/GwaQC52tsbE
I'm attaching the .NC files and the Fustion 360 file I made. I created the program in Fusion 360 with the Carbide 3D post processor.
2.nc
Rough bores for Flat washers
(145.74 KiB) Downloaded 66 times
1.nc
Drill holes
(3.36 KiB) Downloaded 67 times
My Board v15.f3d
Fusion 360
(388.97 KiB) Downloaded 50 times
Re: Z-Axis losing steps and sleepwalking stop command
Post by WillAdams » Wed Feb 14, 2018 4:09 am
For the Z depth, please check you Z-axis mechanically --- make certain that all the parts are in place and tightened suitably --- use thread lock where necessary on parts which don't need to be further adjusted, and that the belt is adequately taut (guitar string tight, but careful not to bend the motor mount shaft).
The lose of connection maybe EMI, see: https://www.shapeoko.com/wiki/index.php ... mendations
